993 Forum 1995-1998
997 headlight
Old 04-19-2009, 01:14 AM
KMASS993
KMASS993's Avatar
Default 997 headlight
Hey,
Has anyone thought about modifying the internals of a 997 headlight to fit in the 993 headlight casing? They seem very similar in shape and style, I don't think the untrained person would even notice the difference. Much better optics as well. The section I am talking about is where the ribbed plastic on the bottom stops and the chrome starts, the dimensions look very similar. Would it be too cyclops looking? I saw some 997 headlights on ebay for $165 each... maybe it would be better to just go with HIDs?
Kevin
Old 04-19-2009, 01:33 AM
Edgy01
Poseur
Edgy01's Avatar
There is a lot more going on with the 997 headlights than one would first imagine. With the Bi-Xenons, you really need to have the washers for them (legal issue) as well as the auto-levelers. I have to say that they are truly the best headlights I have ever had on a Porsche but retrofitting them into the 993 headlight buckets just doesn't seem possible. Even if you could get a good fit (doubtful) there is a lot of other stuff going on to control them that could complicate that project.
Best of luck if you proceed,--also, watch out for eBay ads for those headlights. Many are stolen from 997s in the Florida area and wind up on eBay. You may be contributing to those losses should you chose to buy a $1000 headlight for $165 on eBay. (They are extremely easy to remove).
Old 04-19-2009, 01:52 AM
FlatSix911
FlatSix911's Avatar
Kevin, great idea on the 997 headlight retrofit ... I have considered the same concept myself ...
Don't listen to the nay-sayers who may not have the skills or vision to make it happen. If you do go ahead with the project, be sure to post photos ...
Old 04-19-2009, 02:00 AM
Terry Adams
Terry Adams's Avatar
I just bought the lens and housing part from Sunset Porsche for about $817. No bulbs, levelers or anything. For my TT with just a cracked lens. The part is the one with the red "1". I miss my 993 when a lens replacement was about $75!
The entire bi-Xenon unit is about $1200 at the dealer.
Old 04-19-2009, 02:05 AM
KMASS993
KMASS993's Avatar
Ted,
It may be a fall project... it was just a thought when I saw the picture I posted above. I will be sure to post if a choose to proceed!
Old 04-19-2009, 02:06 AM
KMASS993
KMASS993's Avatar
Terry,
What are you planning to do with your old one? Thanks.
Kevin
Old 04-19-2009, 02:09 AM
Terry Adams
Originally Posted by Kmassed002
Terry,
Kevin
Keep it in case I get hit with more flying road debris.
curve lover
curve lover's Avatar
Kevin-- Anziano's Bad Boys created the following, for sale by LA Dismantlers.
Related RL thread -- eBay: 997 + 993TT + 1989 Speedster = ???
Auction: Porsche 911 Custom Anziano 997 993 Turbo Speedster Look
Also, a RLer on the 993 Turbo forum installed 997 headlights; mayber someone can remind us who. Keep us updated if you make the conversion. Good luck!
Old 04-19-2009, 02:11 AM
KMASS993
KMASS993's Avatar
Curve,
I am not looking to put the whole headlight in, just the innards as they are superior optics. I would never carve up a 993... thats like Jessica Alba getting plastic surgery...
Old 04-19-2009, 02:43 AM
curve lover
I'm arguably good with pix, not words. Your Alba imagery's perfect!
Saw title '997 headlight' & your photo of ... 997 headlight. I'm a simple man. Now I notice key word "internals" in your OP.
Great idea to take advantage of just the upgraded interior components; RLer recently wrote that 997 had best headlights of any Porsche he'd driven.
A little shocking to see below RL TT after eye surgery.
Old 04-19-2009, 10:28 AM
bart1
bart1's Avatar
there was a 964 in the last Excellence with 997 lights. That required some serious work and they look to big. Of course that car had over 1100 hp, so who cares.
Old 04-19-2009, 10:59 AM
Ag02M5
Ag02M5's Avatar
Originally Posted by Terry Adams
What version of PET is that? Looks alot better than the one I have.
Old 04-19-2009, 11:11 AM
ploglet
ploglet's Avatar
If we are able to put the innards into the 993, I will definitely do that. The stock 993 lights suck.
Old 04-19-2009, 11:16 AM
jaholmes
jaholmes's Avatar
I think you are onto something. Just taking the guts out of the 997 body and putting them into the 993 body. It's probably worth a prototype. j
maybe it's been brought up but these things turn too. Probably would have to disable it since the 993 probably does not have any steering inputs. But the auto-level should work.
Even grabbing all the essential parts may be worth a try like the ballast and leveling unit.
Old 04-19-2009, 11:34 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Much easier to just install the OEM Litronics kit IMHO.
But, if you want someone who tackled a similar technical challenge, PM RL member Toby Pennycuff .
He attempted to retrofit BiXenons into a std Cayenne ... he hasn't quite been the same since.
Mechanics apart, you probably could just retrofit the 997 headlight and bypass (or install a manual) leveling mechanism, similar to that done OEM by Euro VW's....
http://www.tmtuning.com/HOME/catalog...t_product=1708
But again, in the end, OEM Litronics would be easier.
Quick Reply: 997 headlight
