faint whine due to SAI pump?
On cold startup, for about the time I imagine the SAI is working, I hear a fiant whine from perhaps the driver side, rear of the engine. Almost like an alternator bearing if it were in the center (which it might be). This started to be evident after my 60k mile tune up (at 55k) in which the check valve for the SAI was replaced. Check valve had been badly blocked before.
Question - does a properly wokring SAI pump make this noise, assuming the lh side SAI ports are blocked (which mine are, at least for cyl 2 - I get the dreaded 0410 code)?
Thanks.
Charlie
97 triple black cab, M030
Thanks.
Charlie
Seared
Charlie,
The pump is located just right of center, at the rear of the engine. A check valve replacement should not affect the actual electric pump.
It's all a distant memory for me though - my SAI pump now lives in Florida...
Andreas
Andreas
If you have a scanner, you might be able to turn the pump on. With the Derametric scanner, you can turn on the pump any time. I did this to check my flow with the engine off, it really pushes some air out the mufflers!
Seared
Hmmm.
Andreas
Seared
