Clutch Slave Cylinder Hose Twisted
Okay....So I'm replacing the clutch slave cylinder and I'm following everyone's advise and tips (as well as p-car.com's DIY). I've got the old cylinder removed and the new one screwed onto the hose (hanging ready to install). My question is: How in the heck to you install it without getting the hose twisted? I did a search and found no results on this. Any help or suggestions would be appreciated. It's the last thing to complete (with a full clutch and break bleed) and then I'm back on the road again.
Zach
Zach
Seared
Install the new slave with the hose already attached. I used the new hose to pull the slave against the mounting studs in order to get a nut started. Once the slave is correctly mounted, attach the hose to the hardline.
Andreas
Andreas
I did get a new hose, but after inspection the old hose looked fine. So you are saying attach the new hose to the new slave and then install with the other end of the hose hanging free? Then attach the other end of the hose to the hard clutch line?
That is what I did and it works. The hard line nut is what rotates.
Also, do you use any type of sealant on the threads of the hose? If so, what do you suggest?
Stupid question.......what do you use to stop the flow of fluid from the hard line when you detatch the slave hose? Is there a plug I can get somewhere?
Seared
Seared
