993 Forum 1995-1998
Fabspeed 993 C2/C4/RS RSR Header Muffler Kit
Old 03-19-2009 | 11:32 AM
John@Fabspeed's Avatar
John@Fabspeed
Basic Sponsor
Default Fabspeed 993 C2/C4/RS RSR Header Muffler Kit
Fabspeed wants to remind everyone who owns a Porsche 993 and runs it on the track, of our RSR Header Muffler kit that is available. Our Header Muffler kit is intended for track use because it doesn’t use any cats and is designed for maximum power and sound. The package consists of our RSR equal length headers with or without heater boxes, a dual inlet/dual outlet muffler and muffler pipes if you wanted to run straight out of the headers for the track. The Header Muffler kit will eliminate the heavy 24 Lb. Stock cat and both 17 Lb. mufflers and replace it with our one Fabspeed muffler to maximize flow and power with the least amount of restriction. If you are looking for a new exhaust for your track car or street car that sounds aggressive, saves lots of weight and makes ultimate horsepower this is the option you want. We have the headers available with or without heat depending on your needs and requirements.
• Fits All 993 C2/C4/RS cars 1994-1998
• Saves 47.55 lbs from the rear of your 993 and the car will feel much stronger and responsive.
• Full bolt-on installation.
• Significantly increases Horsepower and Torque that you can feel. Strongest and finest high performance race system available for all 993 street, race and DE event cars worldwide.
• 14 - 16 gauge T304 Stainless Steel- Much stronger, better quality and guaranteed to be the finest quality in the Industry. Uses CNC Mandrel bent tubing and F1 style high velocity Merge Collectors for maximum flow.
• Strong and deep sports car sound at medium speeds and sounds aggressive through the RPM range!
• 993 Header Muffler Kit Video (http://www.fabspeed.com/993.html)
Visit www.fabspeed.com for more information and product videos for the 993 and to place an order. Please make sure to mention this code (AKRFS05) to receive the Rennlist member discount when placing your order.
The Rennlist member price for the 993 Header Muffler kit is
1. Header Muffler Kit With Heat is $2600 ($100 Discount)
2. Header Muffler Kit Without Heat is $2395 ($100 Discount)
All parts are in stock and ready to ship. We ship internationally as well. Feel free to PM or email me directly at Alex@fabspeed.com with any questions you might have.
Product Photos below on and off the car and photos of the kit with heat and without heat on the floor.
993 Header Muffler Kit With Heat
Header Muffler Kit With Heat Installed on 911
993 Header Muffler Kit Without Heat
993 Header Muffler Kit NO Heat Installed on 993
993 Header Muffler Kit With Muffler Bypass Installed
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
Old 03-20-2009 | 11:53 AM
Fly911's Avatar
Fly911
Alex, I have searched for a sound clip of the RSR exhaust, but not found any. For me the sound is the most important, the difference in power increase of the various aftermarket exhaust systems is insignificant. On the track, plus or minus a couple of psi tire pressure makes a bigger difference than exhaust system power increase, so the souns is the driver for a new exhaust.
Does the muffler have an internal X-pipe, i.e. merger of the two exhaust pipes (6 to 1 with dual outlet)?
Old 03-20-2009 | 02:23 PM
AOW162435's Avatar
AOW162435
Seared
That last picture is pure sex. Does a 993 with that setup sound like a top fuel dragster at idle?
How about offering an unpolished version for less?
Andreas
Old 03-20-2009 | 04:18 PM
roche's Avatar
roche
i want headers for my car too. i'm with andreas...no polish.
Old 03-20-2009 | 06:40 PM
John@Fabspeed
Basic Sponsor
Fly911, we have a 993 on the lift that we are currently installing the Headers with heat on right now so we will have some Videos of both the Headers with Muffler and the Heaters with Muffler bypass pipes. We will post them on our website as soon as there done, so I would check the website for updates. I will also post them up here fro you guys to check it out.
The muffler system does not have an X pipe inside but it uses our own Core design to give it a nice deep growl. Let me know if you have any other questions.
Andreas
Hi AOW, the car sounds very aggressive and sporty at idle, but you have to hear when its under load and at high RPM, its unbelievable. We dont have them in a non polish since we do them in a product line and they look much nicer when polished under the car, but if you guys are interested, I can make you a nice offer if you want to do a small group buy.
Alex@fabspeed
Old 03-24-2009 | 12:04 PM
Fly911's Avatar
Fly911
Alex, according to an e-mail I got from Joe Fabiani (Dec. 5, 2008), the RSR muffler has an X-pipe inside. I also talked to him on the phone, where he explained that the RSR 2 in 2 out muffler has two U-shaped pipes horizontally mounted inside of the muffler, where the pipes are opened and welded together, so the exghaust from the two sides merge (like Dach, Cargraphic and Stebro X-pipes). When you have a 6 to 1 merge on an X- or Y-pipe, you get a 4th harmonic exhaust sound frequency that will give you a GT3 like high pitch sound (music !!!).
So what is correct then, does the Fabspeed RSR muffler have an X-pipe inside like Joe says, or not like you say? Please clarify.
Old 03-24-2009 | 05:41 PM
John@Fabspeed
Basic Sponsor
Fly911, The RSR muffler does have an X Pipe design inside. I got confused with our regular Maxflo Muffler setup. Let me know if you have any other questions and I hope everything is well.
Old 03-24-2009 | 06:47 PM
EckFe1's Avatar
EckFe1
Alex, absolutely nice work. You state that it can be used for 993's up to 1998. What do you do with the 4 oxigen sensors. Do you use an epsilonian device to keep them hooked up or do you change the software? Don't know if that's possible though.
Thank you for your answer.
Ed
Old 03-25-2009 | 12:13 PM
John@Fabspeed
Basic Sponsor
Ed
Ed, the headers have 2 spots to input the primary 02 sensors and the 2ndary sensors you will not need to use, so you can just zip tie them to something on the car and thats it. Let me know if anyone has any questions.
Old 09-10-2010 | 11:23 AM
TYNUSKT's Avatar
TYNUSKT
Was a video/soundclip ever posted for this setup?
Thanks.
Old 09-10-2010 | 12:37 PM
jdistefa's Avatar
jdistefa
3.8 with Fabspeed RSR headers with custom baffles and 3.5" tips
Old 09-10-2010 | 12:42 PM
Fly911's Avatar
Fly911
Since I last posted on this thread, I have installed the Fabspeed RSR header/muffler kit. Compared to the original exhaust, it's way more agressive, all the way from idle to engine cut off @7,300rpm. Above 7,000 it sounds just like a GT3, at least from the inside of the car. Around 3,000 there is a light resonance inside, but not too bad. Fabspeed has posted a video of their 993 with this system, racing on Watkins Glen. The sound is awesome, the headers and X-pipe give it a very different sound than a regular 993 exhaust. But in my personal opinion, I would like it to be even louder. I know that Fabspeed is working with an X-pipe with resonators rather than the dual inlet/outlet muffler, that will make it louder (and maybe also save some weight).
As far as the HP gain, the 993 original headers are very good, and the main HP contributor is probably the cat delete (10-12HP?). For me the sound is the most important. However, for the 946 and older 911's, the HP gain is significant, I have seen claims of up to 25HP, but no dyno to verify the results.
Old 09-10-2010 | 12:53 PM
TYNUSKT's Avatar
TYNUSKT
Do you have a link?
And thanks Matt for posting the other two vids.
Old 09-10-2010 | 12:54 PM
99three's Avatar
99three
If this was EVER proven then I would see a massive GP. Till then it's yet another claim.
Old 09-13-2010 | 11:47 AM
Fly911's Avatar
Fly911
See the video here:
http://www.youtube.com/watch?v=_5vB3Ry7y6Q
