WTB: 18" Technology Wheels
Hey guys,
New here. I'm looking to replace my stock 17" wheels w/ OEM 18" Twist/Technology wheels. If anyone has any, or knows where I can find some, please let me know. I'd rather not use a retailer like Wheel Enhancement, etc. unless I am forced too.
I have read the several threads on the correct fitment for my 96 993 C2, but I am still confused (I have also read up on Pelican parts). The local Porsche dealer tells me the correct p/n for the NB is front: 993.362.136.00 and rear: 993.362.140.00. I start to get fuzzy when you start talking about the offset (ET.....). Are there any other p/ns that work on my car besides the ones listed above? I see a lot of 996.xxx for sale on CL and other sites.
Any help is appreciated. Pics of your Twist wheels would be appreciated.
<---PICTURE
Did you want "Technology" or Turbo Twists?
Hollow Spoke “Technology” wheels:
993.362.136.00 - ET52 - 19.95 lb (front)
993.362.140.01 - ET65 - 23.36 lb (narrow body rear)
Solid Spoke Turbolook wheels:
993.362.136.01 - ET52 - 25.57 lb (front)
993.362.140.04 - ET65 - 29.32 lb (narrow body rear)
Good question...other than weight, I can't figure out the difference between the two. Is there a noticeable difference in appearance between the two? Which ones do you have in your avatar?
I'm about to post some 18" Sport Classic II's for sale which came off of my 993. They are the wheels shown on my avatar if your search expands beyond the Technology wheels you are looking for. These fit the NB 993. Good luck with your search.
Technologies for NB are relatively rare and typically cost almost twice what twists cost on the used market. Twists weigh a ton.
Thanks Jimbo3. That clears up the technology vs. twist mystery. I've seen wheels off a 993 turbo FS with the same p/n, but the offsets are rear: 10Jx18 ET40 and front 8Jx18 ET52. Will these fit my NB? Jhale, thanks for the offer..will keep in mind.
Nope, that is WB rear fitment.
8" fronts are prefered, but 7.5" is more common and will do. 8" will carry up to a 235 tire while the 7.5" is maxxed at 225.
Perfect, thanks for the responses. 2 more questions and then I'm golden. 1. How will I know if ET number....is it stamped on the back of the wheel? 2. Will Twists off of a 996 work? I assume its the same p/n, except it starts w/ 996??
996 twists look different than 993 twists and have completely different numbers, but are the same sizes and offset. IMO, 996 twists are not attractive.
To complicate it just a bit further, there were 7's and 9's made for Boxsters and the part #'s started with "993", but that's another kettle of fish.
