993 Forum 1995-1998
Door Strap Repair
Old Jan 24, 2009 | 05:43 PM
johzev's Avatar
johzev
Default Door Strap Repair
Here are a couple of progress pictures of my door strap project. I'm going the extreme route with fender and door off. When I stopped at the shop yesterday I was surprised to see that even with the fender and door removed you still can't access the spot that needs to be repaired without cutting into the door post attached to the car. When repaired you will not be able to see the work but the door post will need to be cut open.
File Type: jpg
File Type: jpg
Old Jan 24, 2009 | 06:30 PM
Chuck W.'s Avatar
Chuck W.
Wow..... now that is a design flaw. Nice job. I went the cheap way 4 years ago and it has just broken loose.
Old Jan 24, 2009 | 06:37 PM
Cactus's Avatar
Cactus
Noodle Jr.
I am very careful opening my doors because I don't want this problem.
Old Jan 24, 2009 | 09:20 PM
Mike J's Avatar
Mike J
Wow, that is pretty extreme for sure! I had both sides welded up years ago on the ouside, and knock on wood, its all fine. My body shop did the welding, then they ground the weld down so its very smooth, prime and painted, and it looks like factory.
I was looking for a picture to post but I moved from my PC to a iMAC (thank god!!) and I am not sure if I transferred the old picture...
Cheers,
Mike
Old Jan 24, 2009 | 09:38 PM
993_Pilot's Avatar
993_Pilot
Originally Posted by Chuck W.
. . . I went the cheap way 4 years ago and it has just broken loose.
I went the cheap way 6 months ago and it just broke loose again. I was careful too. I guess it's time to cut in to the door frame!
Old Jan 25, 2009 | 02:29 PM
johzev's Avatar
johzev
Would really like to hear from anybody that has completed the expensive fix and has some good photos or info on how they opened up the post and what the reinforcement process was?
Old Jan 25, 2009 | 02:57 PM
trickydisco's Avatar
trickydisco
Thanks in advance to all who share their door check experience/pics.
Mine's clicking.
Old Jan 25, 2009 | 03:15 PM
Chuck W.'s Avatar
Chuck W.
TheOtherEric posted this photo in '06. It is one of the cleanest jobs I have seen. When I go in to have mine repaired again, this photo will be used as an example.
Old Jan 25, 2009 | 10:08 PM
993_Pilot's Avatar
993_Pilot
Mine looked that good too, but it didn't last. Doing the repair from the outside, you are welding the check strap attach point, to thin sheet metal, which will still flex, fatigue, and eventually crack. My body guy recommended cutting in to the frame and adding doublers, i.e. reinforcing the frame with thicker metal, then welding it all back up. It should all look the same when it is done, but the key is to have it properly strengthened, so it will last.
Old Jan 26, 2009 | 02:35 AM
Mike J's Avatar
Mike J
I am pretty sure is actually my car and I took the picture! I posted it long time ago. BTW, the welds are still holding fine after quite a few years. One other secret is to grind down the indents a bit on the arm that holds the door from swinging open so its not so hard on the attachment point.
Cheers,
Mike
Old Jan 26, 2009 | 09:42 AM
willchao's Avatar
willchao
My recent fix looked like this as well, but my shop cut a window through the area and used a sturdier structure behind it for support.
Old Jan 26, 2009 | 11:35 AM
AOW162435's Avatar
AOW162435
Seared
I've heard of someone completing the repair by going through the kick panel area. Does anyone remember this?
Andreas
Old Jan 26, 2009 | 11:48 AM
tigerrat's Avatar
tigerrat
My repair was via the footwell/kick panel but I don't have any details. Looks original from outside. I agree with Mike but trimmed the rub pads on the checkstrap mechanisim to reduce the push/pull force on the attach point. You need to be more aware of wind and parking on hills though. Ken
Old Jan 26, 2009 | 12:03 PM
Chuck W.'s Avatar
Chuck W.
Originally Posted by Mike J
I am pretty sure is actually my car and I took the picture! I posted it long time ago. Cheers,
Mike
Mike… You’re right. I re-read the posting I found the picture on and theothereric stated, “The exact same thing happened to me. I took it to any ol' shop down the street and they welded and painted it for $100. I was armed with the following pic, which helped explain what I wanted them to do.”
Sorry about that…
Old Jan 26, 2009 | 09:13 PM
Mike J's Avatar
Mike J
Hey, no problems at all, I actually was looking for that picture on my PC so I could repost it, but I could not find it...
Thanks for finding the picture again!
Cheers,
Mike
