993 Forum 1995-1998
Has anyone regreted changing to the LWF?
Old 01-12-2009, 05:58 AM
  #46
David in LA
David in LA's Avatar
A bit off-topic, but I think we're just about due to get an update on your car, Chris
Originally Posted by TargaTango
As you can see from the above responses, people's experiences as to stalling differ. OBD is a US polution control system right? If so, I do not have it and still experienced very significant stalling issues on my 1996. I cannot say whether this was mainly attributable to the LWF and/or the 9M sport cams. The problem was much as described above - the system was just not fast enough to detect idle. After much anguish and having two different shops try and cure the stalling, I totally cured the issue by changing from Motronic to Motec engine management and no longer using the air mass sensor but a manifold sensor, and having brand new engine mapping. I undertook this at no small cost, not just to cure the idle issue but to get the most performance out of my modified engine and 100 cell cats. The stalling was maddening and this is what I ended up as pre Motec, but in the end it was all worth it:
Old 01-12-2009, 11:35 AM
  #47
guards red
guards red's Avatar
I would suggest a "live remap" would cure the stalling issue (and give more BHP). They are reasonably popular here in the UK so would imagine they can be done in the US. Basically the parameters in the chip you currently have in the DME is re-programmed to suit your specific car and its engine. This is done on the dyno hence the "live" part of the remap. Will do what after market chips do but better as it's tailored to suit your car. The idle can also be adjusted and the cut off of the injectors is either eliminated or made more progressive so the car will not stall. The vram/resonance flap opening and closing can also be adjusted. Typically here it's £500 for such a service from the best in the business. I guess that's $700-750?
Old 01-12-2009, 11:53 AM
  #48
TheOtherEric
TheOtherEric's Avatar
Originally Posted by jmarch
There's a procedure for checking vacuum in the factory manual. Essentially, you unplug the vacuum line on the fresh air flap and hook up a vacuum gauge. Start the car and rev it a bit to generate vacuum. When you shut the car off, the car should hold the vacuum generated. If it doesn't hold for at least several minutes, you have a leak.
I'll bet ya a number of our friends with stalling problems have a vacuum leak.....
I've wondered if there isn't a simpler zero-tool way of checking for vacuum leaks. My idea is to count how many times your resonance flap will cycle before dying. If you have a scantool, you can easily force the resonance flap to keep cycling. Or just have somebody sit in the car and keep turning the key off & on while you listen for the resonance flap to click (it cycles each time you key-on). I could get several cycles but I can't remember exactly how many offhand.
Or perhaps a $20 boost gauge from Pep Boys will do the trick. Come to think of it, I have a cheapo boost gauge I can try out.
Originally Posted by 4X4SCHE
I am pretty sure that there is a signal from the climate control to the ECU to tell it that the A/C is turned on. This has the effect of increasing the idle speed to compensate for the A/C compressor load. Many people have said that it does not stall with the A/C turned on. This is why.
When I install a LWF, I plan to hot-wire my ECU so it thinks that the A/C is permanently on. Anyone care to try this first?
John
Has anyone actually confirmed this would work? Simply bumping up the idle speed a bit does NOT solve the problem. BTDT.
Old 01-12-2009, 01:08 PM
  #49
tj90
tj90's Avatar
I recently replaced the clutch on my 8/94 late build 95 and had the choice to replace - LWF or DMF... I ended up replacing with DMF. I justified this by telling myself that if I needed someone else to drive the car or was going to sell it to someone who isnt well versed in LWFs, the DMF car is easier to drive. I would hate to lose a prospective buyer trying to explain that stalling is to be expected. With that said, I dont plan on selling but then again, these clutches last a looong time. Who know whats going to happen in the future!
Old 01-12-2009, 01:18 PM
  #50
ca993twin
ca993twin's Avatar
When I purchased Rufus just after the Ruf Turbo R conversion, the previous owner had tried the LWF. He found that the engine would die when coasting down an offramp. He had a new DMF installed. I still have all of the LWF, PP, clutch parts in case I ever wear out the existing clutch.
Old 01-12-2009, 01:32 PM
  #51
Andy Roe
Andy Roe's Avatar
I have a LWF in my '91 C2. I don't have any problems with stalling apart from occasionally when I have the air con on. Before having it re-gassed, it was fine. So, if you don't have aircon, or one that isn't gassed, you might not have any problems with OBD1.
Old 01-12-2009, 01:37 PM
  #52
Monique
Monique's Avatar
FWIW.. and perhaps to add a new information to this thread..:
- Verify all vacuum lines are secured.
- Set idle rpm to 960 rpm. These are the exact figures from the RS Tech manual.
Good luck
Old 01-12-2009, 02:15 PM
  #53
DocTock993
DocTock993's Avatar
There's been a lot of discussion re the pre-96 OBDI cars, but what about the 96-98? Any commentary about LWF vs. staying with DMF for the 96-98 993?
Old 01-12-2009, 03:09 PM
  #54
fast_freddy
fast_freddy's Avatar
I have a 95 with a LWF with no regrets. As Chris mentioned you need to change your clutching syle as well as not clutching in at low revs while coasting to a stop without a throttle blip. My first few weeks with it I stalled maybe 2-3 times. Now if I stall it it's just because I'm not paying attention or just drove my other cars that don't have a LWF and get "used" to their behavior.
Old 01-12-2009, 03:10 PM
  #55
Monique
Monique's Avatar
BTW, I would never think of owning another 993 unless it had LWF; much more involving and a definite zing when you punch the loud pedal.
Old 01-12-2009, 04:15 PM
  #56
slider
slider's Avatar
I have a 94-build 95 and really enjoy the LWF with the RS clutch...quicker rev's and acceleration. I did have the annoying stalling issues, especially under high electrical loads (head lights, fog lamps, heater, etc). However, I recently adjusted the ISV to a higher rpm and that seems to help the ECU "catch" the rpm's on the way down. I wouldn't go back to a DMF...I like the LWF that much.
I learned to do much more heal/toeing to prevent the stall prior to the ISV fix (a good skill), but since I'm now contemplating selling the car (for a 997), I needed to make sure the new buyer didn't have the stalling issue.
Old 01-12-2009, 04:21 PM
  #57
fast_freddy
Don't get a 997. Seriously. I had a 07 GT3. While incredibly capable and great fun to drive it is so capable that at sane speeds around town and on the highway it is dull to drive compared to a 993. I found myself grabbing the keys to the 993 far more often than the GT3 after the novelty of it wore off.
Old 01-12-2009, 04:33 PM
  #58
911CabSteve
911CabSteve's Avatar
I have had the LWF for 3 years and love it.. No stalling issues, no coffe can grinding sounds.. No regrets..
Old 01-12-2009, 04:51 PM
  #59
Father of 3
Father of 3's Avatar
I have a 97 and have had zero stalling issues. I will say that it took me a while to get used to driving with a lwf though. Smooth starts, uphill starts. These are things that gave me trouble in the beginning but are fine now.
Overall a good mod, great given the fact that the cost is the same (if you are changing your clutch anyway). I don't mind the noise at all and actually like it.
Old 01-12-2009, 04:56 PM
  #60
JasonF
JasonF's Avatar
I gotta agree with Freddy...my 997 was numb compared to the 993, not to mention the terrible reliability and build quality. You'll need to go 90mph in a 997 to capture the same fun that can be had in a 993 at 60mph.
Quick Reply: Has anyone regreted changing to the LWF?
