1998 C2S ICV Cleaning
Hello Folks,
Just wondering if someone could briefly walk me through this procedure. I have seached the net but wanted to make sure I do this properly. Maybe this is the wrong time to begin working on 911s. I never worked on any of the previous 3 I owned but it sounds like this is faily easy.
Thanks for your assistance with this posting and my prior posts. Happy New Year to all and continued "safe" driving!
Tim
Tim
The hardest thing about the ISV cleaning is getting the back clamp off. There is no way this is installed when the engine is in the car. When you put it back on make sure you put the nut of the clamp in an easily accessible area for next time. I clean my ISV every time the oil is changed. Very easy DIY.
Mike
Mike
Mike
Mike
Cleaning made a huge difference though, so go for it!!
And join Rennlist while you're at it... you won't regret it.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
This is funny, I just used a flexi-driver last night to replace my air filter. It was the only way I could get to the hose clamp.
The right tools really make all the difference. Usually if I'm struggling with something, I'll stop and think, "1) Am I doing it right and 2) Am I using the right tool." Invariably, one of those answers is "no".
- Dave
- Dave
Guys,
I just pulled the ISV for cleaning last night (first time for me). During the process of removing the rubber hoses from the ISV, a fair amount of rubber dust/debris was created and the inside of the hose leading forward from the ISV (I assume this goes to the intake airflow just past the MAF sensor) is pretty dirty. How much do I need to worry about cleaning this junk out (i.e. removing the hose and flushing)?
Thanks,
-Ruben
Thanks,
-Ruben
Hello,
I am about to do this on my 95 as well and while I was doing my research I felt that the P-car DIY was missing some pictures for me. I hope it is OK to point to a DIY from another Porsche forum (FWIW I never visited that forum before, but came across that DIY through my search).
Detailed procedure with extensive pictures:
http://www.911uk.com/viewtopic.php?t=48841
Hope this helps.
Hope this helps.
another good set of pics/instructions is jackals racetrack.
http://www.jackals-forge.com/lotus/
I cleaned the ISV last month and found it easy to remove with the flex shaft nut drivers.
when installing, put a little vaseline, 303 or dish soap on the inside of the rubber mount before sliding the ISV back into place, this will allow you to move it around some in the rubber gasket.
to connect the rear hose, tilt the ISV so the rear pipe points up about 45 degrees and wedges against the rear rubber hose. smear some more 303 on the inside of the rubber hose and hold the hose and pipe together as you turn the ISV back down. the hose will be pressed back onto the ISV pipe.
removal took 10 minutes, install took 10 minutes, cleaning with spray carb cleaner took an hour.
I ended up taking the rear hose off the intake and cleaning it out as well. It was pretty filthy inside. I did my best to clean inside the fitting on the intake as well, but it is hard to get in there. What I found worked really well for cleaning the ISV was Hoppes and my pistol cleaning supplies (plastic dental picks and cotton squares). Rinsed everything out with brake cleaner after the Hoppes loosened everything up.
-Ruben
-Ruben
Mine is currently soaking in thinners just now... one thing is that most of the write up you see for this are for Varioram models. Mine is pre-varioram and seemed to be a little easier as access is a bit better.
