993 Forum 1995-1998
MWF availability?
Old Mar 12, 2009 | 08:30 PM
Roland 93's Avatar
Roland 93
Sorry gents, a little rushed yesterday. This is probably more for the '95 guys.
The Andial MWF set-up has always been their machined weight ring paired with a single-mass flywheel (aka RS flywheel). They don't sell the ring separately I think, out of concern someone will use both parts without checking the balance. The ring can be mounted to the flywheel in any of three clock positions.
It would be a worthwhile precaution to have a machine shop check the balance of both this ring and a LWF you supply before installing. The ring is leftover from my RSA-RS project.
Cheers
Roland
Old Mar 13, 2009 | 01:44 AM
csertich's Avatar
csertich
Thank you.
chuck
Old Mar 13, 2009 | 11:49 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Originally Posted by Cactus
Where's Walrod???
He is back in Japan -- working too many hours again. Its 11pm, just got back from the track..
Old Mar 18, 2009 | 11:49 PM
Ag02M5's Avatar
Ag02M5
How hard do you think it would be to machine some copies of that piece considering it looks like Andial doesn't want to make them? Looks to be a relatively simple design.
Old Mar 19, 2009 | 12:18 AM
matt777's Avatar
matt777
The one on Ebay just went for $510. I was outbid badly in the last 10 seconds. I was thinking it wouldn't be too hard to make a machine drawing and have one made. It would still be at least $500 with material I would think and you still have to balance it. I'll just stick with the stock unit for my clutch change.
Old Mar 19, 2009 | 12:52 AM
Macca's Avatar
Macca
Congrats Chris. Someone paid a mint.
I bid too (and got badly hammered in the last 10 seconds too!). that was a ridiculous amount of money for a ring. Im sure my new LWF cost about that from Gert!
I took the pictures from the web earlier in the week and sent them to my fabricator (my father was a Fitter and Turner and his old shop still does CNC milling). They looked at it and my flywheel and asked me the application and weight addition. They will come back later this week (they cad cam using autodesk the profile before programing the lathe). I think here in NZ we are a bit lucky with bespoke engineering work at reasonable prices. The price estimate givven was 5-600 NZD (about 250-300 USD). That sounds fair to me.
How difficult can it be to CNC mill a round disc to an appropriate tolerance with equadistant mounting poits to increase the eight of something? I would have thought it harder to take 6-8lb material away from a DMF with out comprimising integrity and getting accuracy for balancing....
My 2 cents
Mark
Old Mar 19, 2009 | 01:14 AM
matt777's Avatar
matt777
Originally Posted by CP
Matt,
My Ruf BTR comes with a Ruf medium weight flywheel. You might call Ruf at Dallas and see if they can source you one.
Good luck.
CP
Thanks. I did check before - big $$$ IIRC. I'm ok with the DMF unless there is reasonably priced MWF. I'm in no hurray.
Old Mar 19, 2009 | 01:25 AM
TX Silver's Avatar
TX Silver
That's about how much I would have bid if I though it wouldn't have gone higher.
Too bad it wasn't for a 996, it would have only been $50.
I'm guessing there would be a few people that would be all over a ring like that. Might be worthwhile for a shop to do the setup and crank out a few of these.
Frank
