993 Forum 1995-1998
Mounting Recaro's in a 993
Old 12-18-2008, 04:59 PM
Bill Verburg
Bill Verburg's Avatar
Default Mounting Recaro's in a 993
Made some progress on the seat mounts
using;
Recaro SPG XL seats
BK R-9066 side mounts
Recaro flat sliders
RS tunnel side belt mounts
Another question,
all the harware is M8 1.25, I would like to use g12.9 but it is proving difficult to come by, is g10.9 or even 8.8 ok?
Old 12-18-2008, 05:58 PM
bart1
bart1's Avatar
Let me know what you need and I can get a quote from Motion Industries. I am sure they can get them in a reasonable time.
Old 12-18-2008, 06:57 PM
travanx
travanx's Avatar
How come the seats, sliders, brackets didn't come with everything? More curious than being sarcastic.
Old 12-18-2008, 07:11 PM
gonzilla
gonzilla's Avatar
Are the side mounts just so that you can adjust the height?
Old 12-19-2008, 09:40 AM
Bill Verburg
They just don't, the installer(me) needs to come up w/ the hardware. Not only that but the sliders and sidemounts need to be driled in a # of places for a proper install.
I suppose you can buy the Porsche pieces
993RS seat parts
964.521.819.01 x2 /L seat mount 279.70
964.521.820.01 x2 /R seat mount 256.37
964.521.065.00 x2 buckle support 18.19
964.803.183.00 x1 pass side tunnel belt buckle 172.85 S/S 000-043-207-24
964.803.183.01 x1 drivers side tunnel belt buckle 172.85 S/S 000-043-207-24
928.521.492.08 x2 seat rail /L inner 392.27
928.521.491.08 x2 seat rail /R inner 392.27
928.521.525.03 x2 connecting rog long, adj 5.54
N902.514.01 x4 clamping sleeve 0.29
N902.515.01 x4 guide bush 1.44
911.521.533.01 x2 handle 1.94
959.803.701.00 x1 bolt 5.61
N011.655.2 x2 washer 0.18
999.028.014.02 x2 spring washer 0.54
900.186.135.02 x12 M8x20 cheesehead bolt 0.43
999.093.010.07 x8 M8x20 hex head bolt 2.48
999.025231.03 x8 washer 8x27x3
Old 12-19-2008, 09:41 AM
Bill Verburg
The rear height is fixed, the front can be adjusted by using different slots, so it's the angle that is adjustable.
Old 12-19-2008, 10:21 AM
Flying Finn
King of Cool
Flying Finn's Avatar
Originally Posted by Bill Verburg
...Another question,
I used 8.8 when I installed my bucket seats and they're fine, that's what Porsche uses.
Old 12-19-2008, 12:47 PM
potent951turbo
iPod Tamer
potent951turbo's Avatar
Bill, what is the part number for that thin headed bolt for the RS tunnel side belt mounts in your first picture? I didn't order one like that when I got mine and now I am guessing I should have.
Old 12-19-2008, 01:37 PM
Bill Verburg
Thanks!, I found some 12.9 zinc coated at Lowes of all places
M8-1.25x20 allen heads work perfectly for the side to slider mounts x16 is a tad short and x25 too long to allow full slider travel.
Old 12-19-2008, 01:44 PM
Bill Verburg
The bronze belt receptacle bolt?
959.803.701.00
it' also the stock 993 bolt
Old 12-19-2008, 02:14 PM
potent951turbo
iPod Tamer
959.803.701.00
Thanks, I think I might need to get some of those for my Recaro install.
Old 12-19-2008, 03:00 PM
icelatte
icelatte's Avatar
When I did my recaros, I used the Brey-krause side mounts that included a belt mount. Only problem was that I needed a shim to tightly secure the seat belt receptacle. I guessing you're putting in
harness receivers instead.
Old 12-19-2008, 04:16 PM
Flying Finn
King of Cool
Lowes & Home Depot is always worth the look if they're close by! I usually get stuff from the "allbolts" or what the hell that name is but local hardware store or Home Depot is close and they've rescued me few times.
Old 12-19-2008, 06:23 PM
Bill Verburg
Another piece of the puzzle, Rennline harness mounts for both the door and tunnel sides. A very impressive product and they supply all the hardware(this may seem like a minor deal but it's not) Kudus!!
Old 12-19-2008, 08:06 PM
North Coast Cab
North Coast Cab's Avatar
Bill,
Please keep updating. When I installed my SRD's and harnesses I made a million adjustments and custom parts and am still not happy. I did not use the Rennline items though. I would like ot be able to easily clip and unclip the harnesses. That means you need factory belts which left with the stock seats. So, I bought another set of rear receivers and mouted them on the tunnel too.
Quick Reply: Mounting Recaro's in a 993
