993 Forum 1995-1998
Hole saw question for the fabricators here
Old 12-11-2008 | 04:09 PM
AOW162435's Avatar
AOW162435
Seared
Default Hole saw question for the fabricators here
Where can I find hole saws that will cut 16g sheet metal - and do so without dulling after a few uses? Specifically, I'm looking for a 4.5" saw to be used with a large drill press. I've used a normal Lenox version from Lowe's that went dull after two completed cuts. That's a horrible ROI for $35...
Andreas
Old 12-11-2008 | 04:27 PM
jscott82's Avatar
jscott82
Brother Andreas
While the lenox bits arent top of the line, they should last a few more cuts than two... My initial though was too much heat (teeth loosing thier temper)... that could be caused by 1)not enough lube 2)lube too thin, or more than likely, 3) too much speed.... So a quick search... a 4.5in hole saw should be turning 75 RPM for mild steel.... I dont know a drill press that can turn that slow....
Better question though... whatch ya cuttin' ???
Old 12-11-2008 | 04:44 PM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by jscott82
Brother Andreas
Brother Scott,
I tried a variety of speeds, as low as 300. And I kept the cut lines well lubed. Sounds like I may need to sprinkle some carbide into the mix...
16g steel.
Andreas
Old 12-11-2008 | 04:54 PM
jscott82's Avatar
jscott82
Originally Posted by AOW162435
Brother Scott,
16g steel.
Andreas
You can appreciate this....
My grandfather ( the epitome of a gear head) had an 8 foot tall drill press frame that he salvaged from a manufacturing plant…. He proceeded to scavenge up a 10hp electric motor and two 4 speed car transmissions that he put in series… This thing would spin a 5 in twist drill bit at 10 or 20 rpm and 4 bazillion ft/lb of torque… it was amazing… to change speeds you simply shifted gears...
Old 12-11-2008 | 04:58 PM
AOW162435's Avatar
AOW162435
Seared
Awesome! That should be in your garage, next to your five-foot-long torque wrench...
Andreas
Old 12-11-2008 | 06:10 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Slow down the speed even more, perhaps 150 rpm. -- more than likely the cause of this. For steel, use oil.
chris walrod
Guru
Rennlist Small
Business Sponsor
second thought, use a punch press
Old 12-11-2008 | 07:46 PM
mr_bock's Avatar
mr_bock
Andreas,
That is a large hole for rather thin metal. You may want to get a nibbler and cut near the line and finish with a file. How many holes do you have to make? Is the steel in a flat form? You could have a machine shop laser cut it. I have cut holes with the sheet metal sandwiched between sheets of wood th keep the hole saw from wandering and the metal from bending up as you cut thru the metal.
Good Luck!!!!!
Old 12-11-2008 | 07:55 PM
jscott82's Avatar
jscott82
Ah.... even better.....
Old 12-11-2008 | 08:22 PM
AOW162435's Avatar
AOW162435
Seared
Looked around my shop and came up empty handed....
Andreas
Old 12-11-2008 | 10:29 PM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by mr_bock
Andreas,
Good Luck!!!!!
Actually, I'm cutting a number of discs, so repeatability is key. Although the hole saw simply stopped cutting after the second hole, the teeth still 'feel' just as sharp. Probably meaningless...
Andreas
Old 12-12-2008 | 07:58 AM
Garth S's Avatar
Garth S
Flip the sheet over - they're usually softer on the belly side ....
Old 12-12-2008 | 10:12 AM
jscott82's Avatar
jscott82
Now thats funny !!
Old 12-12-2008 | 11:05 AM
Smiles's Avatar
Smiles
It might be helpful to let us know what you're working on, Andreas.
I assume that the size isn't too important, becuase a 4.5" hole saw gives you a OD 4.5" hole, not a 4.5" blank. The circles you're making are two hole-saw-material-thicknesses smaller in diameter.
Just given what I know, I would make a center punches, scribe the circles with a divider, make a rough cut with hand shears, and then do a final trim with the same.
Have you had a tetanus shot in the past ten years?
Old 12-12-2008 | 12:03 PM
AOW162435's Avatar
AOW162435
Seared
This.
Andreas
