Yank on it! Just watch the forehead. You WILL hit yourself if you're not careful. I just did mine. I didn't understand how it came off (even after reading just pull it). Finally I got pissed off and yanked it real hard, not caring if something broke.
Put a vice grip on the metal shaft of the shifter and use a pry bar on the bottom of the ****. Use appropriate padding under the vice grip and pry bar to make sure you don't scar anything...
Yank it like you're 15 years old. Just don't hit yourself in the forehead .
+1. But I smacked myself in the forehead like you wouldn't believe the first time I did it. I swear you could see the shift pattern backwards in my forehead.
The shifter rod has a notch on it, and the shift boot probably has a protrusion to fit the notch. The notch is on the front and back of the top portion of the shifter. The secret is NOT to put pressure or grab at the front and back of the shift boot, but rather on the sides. It should come off easier that way.
