Anyone Have Any 993RS Cams They Want To Part With?
Found myself in a bit of a pickle and need a set of cams. Anyone have anything they want to sell, new or used?
http://www.schuitemakermotorsports.com/
Give him a call John..he is down in Cincinnati and last time I talked with him he had some fancy 911 pieces in his shop.
Noah,
The 9m Sport cams have been made with the maximum timing that can comfortably used in a stock 964 or 993 engine using the stock intake manifold. In comparison to the 993RS cam ours lift both the intake and exhaust valves more and have slightly more duration, typically adding 20hp onto the top end of the rev range (refer to the 9m Motec +1 info on our website) without screwing up the idle quality of the engine. The price of these cams is £790 per pair (excluding taxes & shipping).
I found some local 993 cams in excellent shape, but without key notch. Still hoping to find some RS's quick. If not, anyone know where I can have the key slot ground?
