Rennline Engine Brace Gusset Kit & Radio/HVAC Block off Plates **Product Release**
Basic Sponsor
![](http://www.rennline.com/images/products-release-image.jpg)
Rennline Engine Brace Gusset Kit **Product Release** $75
One of the only weak points on the 964 and 993 chassis is the engine carrier. When these models are tracked, or are fitted with stiffer than stock engine mounts, the engine carrier should be reinforced. If it is not, the carrier is known to bend, crack, or even break cleanly away from an engine mount in response to increased vibration and stress. The Porsche factory was aware of this problem and equipped its race cars with a reinforced engine carrier. Rennline now exclusively offers an engine mount reinforcement gusset kit that can be welded to the engine carrier by your shop.
Not a welder? Let rennline take care of this for you. Simply send us your motor mount, we will sandblast your carrier, expertly weld on the reinforcement,and will repaint the new carrier to look stock for $250 including the gusset. Send to this address.
Once we receive your mount, a Rennline representative will contact you regarding payment. There is generally a 4 day turn around time once payment is received.
Right Click and Save As to view these installation instructions.
![](http://www.rennline.com/images/m-04_1.jpg)
![](http://www.rennline.com/images/M04-1.jpg)
![](http://www.rennline.com/images/M04-2.jpg)
![](http://www.rennline.com/images/M04-3.jpg)
Radio and Heater Control block off plates **Product Release** $30-$40
Until now, removing the center console from your 964/993 was not possible due to the required switches that where mounted in it. Rennline's new radio and heater control block off plates solve that problem. These plates have been specially designed to accept the factory switches installed in the center console of all 964/993 cars. Don't have the factory switches? No problem. These plates are also available without switch cutouts so you can install your own switches or gauges. Made from powder coated metal and install in minutes on cars with the radio or heater controls removed. Available in 6, 3, and 0 switch configurations.
The purchase these items please click here
![](http://www.rennline.com/images/i20.jpg)
![](http://www.rennline.com/images/i20-1.jpg)
![](http://www.rennline.com/images/i20-2.jpg)
![](http://www.rennline.com/images/i20-3.jpg)
