HID's (YES, AGAIN!), best quality/price
#31
I'm not a n00b and yes I did search and this is the thread I found...
I'm really considering a 993 (probably a 1996 coupe, manual, blah blah), but I've been having a hard time finding any with factory Litronics. I'm not a big fan of non-OEM parts like lights, so the question is this:
Is it possible to retrofit Porsche OEM Litronics to a non-Litronic car? Cost is not the issue (I'm guessing it'll be about $1000-1500), but I want to make sure it's a cut-and-dried swap.
Thanks in advance!
EDIT - looks like VHanzon might have answered the question:
And I found prices are around the $2000 mark.
If anyone has additional input or things I should know, please chime in!
Thanks in advance!
I would take the $1800 you have left and put it into other mods if you want to spent it..
Cheers,
Mike
#32
Super Moderator
Needs More Cowbell
Needs More Cowbell
Thanks in advance!
Thanks in advance!
I bought an OEM Litronics kit from Sunset Imports for about $2K and had them installed in my wife's 97 Targa. Perfect OEM install, no issues.
#33
Personally, I think it would be a waste of money to buy the litronic lights...the aftermarket lights are just as good and about 1/10th the cost. If the bulbs burn out, its often just cheaper to buy a new kit.
Cheers,
Mike
Cheers,
Mike
#34
I guess I'm not really worried about the lumen output or any of that - I am looking more toward ease of installation, ease of replacement down the road, etc. Looks like I need to do a little research... The 993 is about a year away as it is. When it comes time to buy, I'll be asking you guys for the litany of what to look for, what to avoid, etc. Thanks for the advice!
#35
Here ya go Tim.
This thread is what I used for instructions. Search HID in the 993 forum. http://forums.rennlist.com/rennforum...&highlight=HID
Search the Bay for these:
Super Slim HID Conversion Kit 9006 9007 9004 H1 H3 all
Easiest upgrade ever. Cost me a total of 140.99, and 30 minutes max!
I haven't figured the best solution for the fogs yet. I purchased two LED lamps but the polarity was backward. I'm interested in what everyone else is doing.
I did find another link to the TSB for the repair kit for the Bulb Retaining setup and ordered those parts from my dealer yesterday. My car has had that problem since I got it, I jerry-rigged a fix for it but will glad to get the "official" fix installed soon. P/N = 000 043 204 28; TSB 9415 (?)
#37
#38
The OEM retrofit may be a bit of a chore to install vs. the slim in the headlight aftermarket unit. The OEM system has a ballast on each side in the trunk compartment and ignitors in the headlight units. All this can be installed without great drama but the newer, small units can fit the whole package in the light bucket itself where it is safe and dry and is easiest to install. The newer units, while not OEM, are actually better (not to mention cheaper) so if you go the OEM route you are actually paying more for older technology. The light output should be the same either way.
Another plus of the DIY slim-ballast route is that you can wire it up so that it is fully reverseable if you use connects rather than inline wire splices...mine is set-up so that if the bulb burns out while I am in the middle of nowhere, I can still swap in a factory halogen bulb and use the old wiring.
#39
High Beams
On occasion on back roads I have needed high beams. When they are on, the light is such a yellow color compared to the HID's I installed. I just saw a listing on _bay for a HID replacement kit wherein the seller mentions using LED bulbs for the high beams. Anyone found such an item that could be recommended?
#40
As promised a pic of HID's and LED side lights.
It's worth noting that the sides seem to fill the pic much moreso than real life , they're more a 'point' of light in reality..
Also apologies , photo was taken with a pretty awful 2megapixie camera
#41
#42
#43
I'm seriously thinking of installing these lights as the OEM lights are just atrocious in the dark Northeast winter. What color temperature do 993 people go with? 4300? Other than FJT2000, any recomended alternatives closer to US? Just curious, in case replacement bulbs are needed.
How large is his slim ballast, anyway? Did anyone measure it? Would it be different than, say, this $80 kit: http://cgi.ebay.com/ebaymotors/Super...1%7C240%3A1318 ?
Also, of teh veriety of kits he sells, what are we looking for? H1 slim kit? Or something else?
#44
Wallflower
I have an aftermarket kit in my 95 and love it. The PO installed it and I can't imagine driving it at night w/ the stock lights.
I'm also bothered by the yellowish fogs and want to do something different with them, but I haven't decided what to do yet.
#45
I just emailed this guy: http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123 and got a reply, which is always a good sign. I think I'll be getting his kit as it's only $70. The question remains - go with 5K or 6K color? H1 kit, right?
