Arrrrgh!! RUF's rub the front springs!!!
I recently got 18" RUF RCT's (think 965) with ET61 offset. They are rubbing the front springs!!! The car is normal ride height 1995 993. Tires 235/40/18. Tires dont seem to rub, just the rim of the inner wheel.
Suggestions please?????
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Seared
Typical 18" 993 offsets are 50/52 front and 65 rear. Your front offset is certainly not too far from suggested, but may be just enough.
Andreas
I am running 19" RUF's on a NB car...no rubbing issues. However, I am also running PSS-9's, where the spring diameter seems a bit smaller than stock (just what I remember).
A good question though...what is your suspension and alignment settings (i.e. do you have lots of camber in the front?).
cheers,
Mike
cheers,
Mike
