Arcing coil wire?
I was checking the oil level today and noticed some small arcing at the base of the coil wire boot at the upper distributor. Would this be an indication that the coil wire is shot? I did the caps, rotors and plugs apx 4K miles ago. I haven't noticed any lack of performance, but this can't be normal. '96 C2 w/ 70K miles
I had a similar problem at one point... even after applying dielectric grease, it would still arc.
Turns out, one of the plugs wasn't *perfectly" snug - once it was, no more arcing.
Might be worth double checking them all.
RL Technical Advisor
Well I guess that gets added to my "over the winter" list of projects. I have seen a post for a guy that sells the wire only cut to length. My boots look pretty good, is this an acceptable option?
A proper set contains all new wires, boots and connectors.
+993
How does a properly functioning boot "look" ? ...and why half step a job that needs to be done in its totality? Unless of course you dont mind doing it over again in case you miss something in the "look"
Do you recommend the OEM Beru wire sets, only; or are there some alternatives worthy of consideration? I suspect I know your response, but it never hurts to ask...
Thanks in advance!
