993 Forum 1995-1998
3rd Brake Light -> LEDs
Old 03-01-2010, 03:10 PM
  #91
sce46m3
sce46m3's Avatar
Thanks much Nick. Got the parts and did the whole thing in about an hour. Works like a champ and no more "missing teeth" Just another example of why this is such a great forum for the upkeep and improvement of this great cars.
Old 03-09-2010, 03:10 AM
  #92
jo-hans
jo-hans's Avatar
Thanks Nick for the kit.
This project took me more then an hour for sure but one thing I decided to do before soldering the LED's on was bending the legs much like the the bulbs that came off the bar. The poles of the LED's show a flat spot on each and this is where I placed my needle-nose pliers bending 45°, then using the thickness of the tip of the pliers for the second bend. This allowed for consistent seating in height of the LED's and at the same time I ended up with a good alignment of the poles to the holes.
Even though I lined the long legs up with the black wire side I ended up having to reverse the black and brown wires to the light bar to make them light up.
Old 03-10-2010, 11:32 AM
  #93
michaelh993
michaelh993's Avatar
Nick,
any more kits available?
thanks
Old 03-10-2010, 05:59 PM
  #94
tonypai
tonypai's Avatar
Ditto, I'd buy a kit as well.
Old 03-10-2010, 10:21 PM
  #95
AOW162435
Seared
AOW162435's Avatar
Nick,
PM sent.
Andreas
Old 03-11-2010, 02:41 AM
  #96
Warpig
Warpig's Avatar
Great Idea. the little flat spots is exactly how far i pushed my LED's in but I didn't put the bends in them like you did.
Check your PM's guys.
Nick
Old 03-11-2010, 11:35 AM
  #97
boulderbobo
boulderbobo's Avatar
PM sent to Nick.
Old 03-14-2010, 01:41 AM
  #98
Warpig
Warpig's Avatar
I believe i have responded to everyone via PM. Check your PM's. Please PM me if I've missed you.
Nick
Old 03-14-2010, 12:14 PM
  #99
Todd B
Todd B's Avatar
Nick,
PM sent
Old 03-15-2010, 03:23 AM
  #100
Warpig
Warpig's Avatar
OK I think I have PM'ed everyone at this point. Will try to get these all out Monday or Tuesday.
Nick
Old 05-15-2011, 02:52 AM
  #101
AOW162435
Seared
AOW162435's Avatar
Time to wake this thread up.
Nick,
I purchased the 'white' kit from you more than a year ago. Tonight, I decided enough was enough. I removed my basket handle and de-soldered all of the old bulbs (two were bad). I did the same as Jo-hans and gave each LED two bends to mimic the stock bulbs.
When it came time to solder the LED bulbs into place, I carefully positioned each one, and then spread the 'legs' flat on the other side of the circuit board. This kept each bulb positioned nicely for soldering. Since I had a spare baskethandle insert in my shop, I used it as a jig to hold the circuit board - with the LEDs snugged into the holes. This way, I was assured that they would all be aligned as I soldered.
I installed the resistor on the outside as well, and found that the wire orientation (brown-brown, black-black), worked correctly the first time I plugged the strip in.
I'm very pleased with this minor, yet worthwhile mod. Thank you for taking the time to figure out & ship the required supplies.
Andreas
Old 05-15-2011, 08:49 AM
  #102
DanL993
button queen
DanL993's Avatar
+1 I PMed Nick separately. Got this done early last year (with adult leadership on the soldering part) and the light looks great.
More memorable was Nick's unselfish help with parts and instruction.
DIY stuff like this is the best part of Rennlist. Thanks to all.
Old 05-15-2011, 01:36 PM
  #103
aircooled
aircooled's Avatar
+ 993 for Nick as well.....made the mod a real winner with the correct parts and great write up.
I'm gonna keep that basket handle "forever"...
Old 05-15-2011, 07:33 PM
  #104
AOW162435
Seared
AOW162435's Avatar
BTW, if anyone would rather replace their burned-out stock bulbs with the same, PM your address and I'll send however many you need (I have 20 or so good ones).
Andreas
Old 05-17-2011, 04:26 AM
  #105
Warpig
Warpig's Avatar
I still have a bunch of the original lamps sitting here collecting dust too that I'd be willing to pass along to people in need. I don't need them anymore
Nick
Quick Reply: 3rd Brake Light -> LEDs
