Oil pressure vs Oil temp...
I noticed that my oil pressure guage was in between the 1-2 bar at idle (closer to 1 as it was getting hotter in traffic) with the temp between 9-10 o'clock. Seem kind of low? 40K with brand new M1 5-50 oil. With a hot motor where does your oil pressure sit at idle?
At idle, oil pressure should "remain between 2.0 and 2.5 bar" at 70-90 deg. C., according to the 993 service manual. Sounds like your car's engine's oil temperature in traffic is running close to 120 deg. C.--close to too hot.
Once my oil temp starts heading towards the 9 pos'n , my pressure at idle heads towards just above 1 bar .. 50k miles on the clock.
is your low speed fan kicking in just above 9 o clock?
As already stated, check your oil cooler fan.
No worries Serf, it's normal, mine does the same when I am stuck in traffic: oil temperature slightly above 9 o'clock and oil pressure at between 1 and 2 bar. I use the same oil as you. Until last year, I was running M1 15w50, the pressure would never drop below 2-3 bar. I guess that thinner oil means lower pressure.
Oil pressure is adversely proportional to temp. As oil temp goes up, the viscosity goes down, so you get slightly lower pressure.
IMHO, I have found that M1 seams to have lower pressure then most other top synths.
Yes, mine sits just below 2 bar at idle, but last week with the hotter temps it was more like 1.5 bar.
I use M1 15W50, and my oil cooler fan is always on high speed (by design, not accident). Temp hovers around the first mark. 78K on the clock.
Thanks for all the responses guys. I t turns out that I am using M1 15-50. There's a definite relationship between heat and viscosity, one goes up while the other goes down. I think my gauge is slightly off. It has never pegged at 5 even at start up, just slightly under 5. I figure the rest of readings will be skewed as well.
Update and good news (I think?) I did a diagnostic on the oil cooler fan. With the assistance of PCar Workshop on RL.
I checked the relays and jumped terminals 3(30) and 7(87c) for slow speed : Does not work! I then jumped terminals 3(30) and 5(87) for fast speed : Works fine! Same with the AC condensor fan speeds.
Next. With the car started I turned the AC on and the condenser fan started. Good news.
Next. I removed what I think is the oil temperature sensor cable (from the passenger side headlight) to invoke the high speed fan. Now it's always on.
Does the oil cooler fan resistor need to be replaced?
Addicted Specialist
No cons to leaving the bad resistor in except that you "may" forget to check your gauges and therefore must rely on manually kicking the fan in to cool the oil. So it's up to you. But anyone driving any 911 should make it a habit of check gauges regularly ...especially an oil-cooled car.
Edward
