paint meter guage to buy?
I just bought this one: http://highlinemeter.com/index.html
Works amazingly well for steel and aluminum. It's my new, secret weapon when I go car shopping. Downside=doesn't work on plastic. However, I'm really not too concerned if a bumper has been re-sprayed. You can spend four times as much for a paint gauge that the car dealers use.
I'm sure Mike aka Arena993 has some suggestions.
Mike
I have the Quanix 4500. It works well, easy to use, reads in microns or mils, reads on steel or alum., and has a long battery life. I like it a lot. The only thing I don't like is that you have to manually switch between steel and alum. Whatever brand you buy, don't cheap out. The higher-end gauges read to +/-.1 mil, whereas all the cheaper ones only read to about +/-.5 mil. That's too much variation to be accurate enough. Mine was not cheap, I see they're around $600 now.
On Porsches up through 964's, you're going to see readings on single-stage paints of 4-6 mils. It varies because these cars were painted by humans. Clearcoated paint of that era I'm not sure about. I would expect it to be about the same to slightly more. I've "mapped" my car, and it's funny to observe how they shot more on the horizontal areas vs. the vertical panels - but the pattern is symmetrical side-to-side. 993's I'm not sure about, because I don't know if they were still painted by humans. What you're really looking for is a red flag, like startling variations between panels. Even if a panel is stripped & painted, you're still going to see a variation vs. the adjacent panel - OR you're going to be able to note where it was blended. These gadgets are handy and fun - they do stop the bullsh*t cold about whether something has been painted or not.
This technology came in handy when I bought my car sight-unseen from 2000 miles away. I asked for paint-meter readings, in writing, on all panels. Based on those, I was pretty confident the car had not been painted.
ps
I'm pretty sure the girl in the picture has been repainted - but no bodywork done .
ps
I just use the (cheaper) Fender Splendor model. I think it depends on what you need it for. For the occasional used car purchase the cheaper ones work well and will pay for themselves the first time you avoid buying a repainted car. You're really looking for the changes in the readings more than anything else. Of course things like the tailgates on SUV's have much lower thickness readings than the door panels of the same vehicle (from my experience). They will pick up bondo on the older cars and I did a car the other day that read from a low of 5.5 to 24.0, not counting the 2 spots where the bondo was applied. (the car was a '70 Ford Mustang Mach 1, 351)
http://www.wholesalepaintmeters.com/
Horizontal above 100 microns (going up to 190 in same spots) and vertical all under 100 (most between 85 and 95).
My 993 is metallic paint, the 964 is not. Both original paint.
I have a gauge from Wurth which looks identical to yours btw (except it's orange) and comparing my 993 and 964 the readings are virtually identical.
By comparison, my robot-painted Japanese cars show a very even paint thickness with a very narrow range.
I can imagine that you get consistent readings, but how accurate are these? Do they ever need to be recalibrated? Or is consistency the important thing you're looking for?
(I'm not trying to be smart, but part of my work involves tension testing, and the above applies there, too.)
I've never heard of one of these needing to be recalibrated by the factory.
The Quanix came with bare strips of steel and alum. to zero-set before you begin taking readings.
