Braided Brake lines
New shocks and springs (M033 + Monroes) on the way. I want to change out the brake lines and pads while I'm in there. The car is mainly a NJ DD + 5-6 AutoX's per year. Any suggested brands and sources or should I stick with the OEM rubber lines and pads? Thanks.
I purchased my SSbrake lines through Paragon Products. I believe they are in Florida(not positive) They seem to be pretty awsome. Tight brakes rock!!! Im sure SS brake lines are tons better than OEM rubber. As far as the pads go , I stayed OEM on them. Sunset out of Oregon gives good pricing on OEM stuff. Good luck and have fun!!!
I got mine from Stable Energies in Garfield. I have no idea as to the "brand". Been delighted with them, they give a very nice firm feel to the pedal.
I always purchase Goodridge lines, they are very, very nice, but usually cost a little more. I've had a set for the C4S, the day after I brought her home.
On the PCA tech board, Joel Riser(tech chair) advises against them. His opinion is that the stocks are great as is and the stainless have a tendency to not be as compliant hence greater chance of leaks down the road. Just saying.
If you get a quality SS line, it is BETTER then the stock rubber ones, I HAVE seen the rubber ones fail on the track, it's not pretty! No one I know has had a SS line fail.
For the life of me, I can't see how they could leak. There 3 pieces, one line & 2 end points, there the same as the stock ones, but don't bulge when pressurized & have a FAR higher abrasion rate. Of course much firmer pedal & far better brake modulation.
I have had Goodridge lines on almost every car I have owned, on my M3, they were on there for 11 years with no issues! That's a few hundred track days.
If you get a quality SS line, it is BETTER then the stock rubber ones, I HAVE seen the rubber ones fail on the track, it's not pretty! No one I know has had a SS line fail.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
It's the same as the OEM line, there is no difference, I really can't see this happening any more then with the OEM line. Maybe if they are installed wrong, & the line is to short, then as you turn the wheel, it can tug & loosen up the bolt by tugging at the banjo>?
I've always wondered why companies like Porsche don't just have SS lines on the car to begin with. I too am of the opinion SS lines are generally superior and I can't believe the incremental cost is much especially if the "upgrade" can be advertised as a feature...or at least offered as an option. It would appear the manufacturers don't see the difference as that big a deal. It makes me wonder if we are victims of thinking in terms of yesterday's technology where perhaps at one time there was a big difference but not so much today.
By the way, AFAIK most flexible brake line failures I've seen or heard about resulted from old age where the interior of the soft line swelled and closed up - a problem braided lines could still have. A properly routed brake line shouldn't abrade itself to death.
