993 Forum 1995-1998
Replacing A/C ballast resistor
Old Jun 10, 2008 | 04:21 AM
PD2FLY's Avatar
PD2FLY
Default Replacing A/C ballast resistor
Need to find a DIY for replacing the A/C ballast resistor. Did BS911's "COMPLETE A/C Diagnosis". Thank you! Replaced the drier and expansion valve and had the system refilled to proper levels. A/C works great but only when high fan is on. Low fan inop. Bought a new ballast but not easily seeing where this guy lives? In side the fan housing? Opened up the drivers front fender well and think I'm to the "help me now" stage! Tks Hubb
Old Jun 10, 2008 | 08:07 AM
jimbo3's Avatar
jimbo3
<p-car.com>, DIY section.
Old Jun 10, 2008 | 08:56 AM
Bill Verburg's Avatar
Bill Verburg
The AC ballast in on top of the AC condenser and angled to the chassis side. Use a small mirror to see what it looks like. You may also be able to access it by pulling the drivers side head light.
I found it easiest to just drop the AC condenser, which is very easy to do
Old Jun 10, 2008 | 09:47 AM
JasonF's Avatar
JasonF
I was able to get to it by taking off the wheel and removing the inner fender liner. That way you won't need to do a full bumper drop. It's a really tight squeeze, but with patience and a lot of cursing I was able to swap the resistor.
Old Jun 10, 2008 | 10:30 AM
dbf73's Avatar
dbf73
Is the car drivable whilst the bumper is off or is there stuff hanging? I was thinking of taking the car to the body shop, having them remove the bumper for a bumperette delete and respray and while that was being done, take the car home and do the resistors. Workable?
Old Jun 10, 2008 | 10:51 AM
JasonF's Avatar
JasonF
I would be concerned about the stuff that's left exposed (oil cooler/ac cooler, various fans, etc...). How about taking the car to the shop, having them match the paint color in person, go home where you remove the bumper yourself and then drop the cover off?
Old Jun 10, 2008 | 11:26 AM
dbf73's Avatar
dbf73
I'm not sure they need the car to do the matching - the bumper itself should be enough. While I probably can get the bumper off easily enough, I'd rather have them put it on, both to have it done right and to make sure I don't hack up the new paint. This would leave just one half hour drive with the front exposed.
Old Jun 10, 2008 | 12:43 PM
PD2FLY's Avatar
PD2FLY
I had been hoping for an easy fix. I see this is not going to be the case. Do I really need to pull fan and condenser to R/R the resistor. Don't se the headlight idea at all?
Old Jun 10, 2008 | 12:52 PM
Deadeye's Avatar
Deadeye
If it's similar to oil cooler resistor I unbolted the cooler assembly and dropped it just a few inches for access. It added maybe a 1/2 hr to the job, but I couldn't get at it otherwise.
Old Jun 10, 2008 | 05:25 PM
BobbyT's Avatar
BobbyT
It is quite easy to replace these resistors working through the headlight opening. Just unplug the wiring harness, leave the dead resistor in place, mount the new resistor on a fender bolt, inside the headlight area, and plug it into the harness.
Old Jun 10, 2008 | 06:04 PM
Deadeye's Avatar
Deadeye
BobbyT, do you have a photo of the resistor installed in the headlight area? I will be attempting this side (AC resistor ) this coming weekend and would prefer your solution.
Old Jun 10, 2008 | 06:39 PM
BobbyT's Avatar
BobbyT
Hi Deadeye,
There is more info here:
https://rennlist.com/forums/showthre...llast+resistor
Sorry, the pictures are no longer at photobucket, and I can't find them in my magic filing system.
Old Jun 10, 2008 | 08:20 PM
jimbo3's Avatar
jimbo3
+1. Easy job, actually. 45 minutes start to finish the first time I tried.
Old Jun 25, 2008 | 12:08 PM
dbf73's Avatar
dbf73
from my perusal of the parts catalog, it appears that both oil cooler and ac resistors are the same part no. - correct?
Old Jun 25, 2008 | 01:03 PM
AOW162435's Avatar
AOW162435
Seared
Correct.
Andreas
