993 Forum 1995-1998
Don't be afraid to dye your seats!
Old 07-15-2008, 02:33 PM
  #46
Boeing 717
Registered User
Boeing 717's Avatar
Hey guys great post. For those of you who have used that colorplus stuff would it work well on my steering wheel and knee pad on dash, In black????
Old 07-15-2008, 02:39 PM
  #47
MarkD
MarkD's Avatar
Originally Posted by Raptor
Guys: I've read that a touch-up gun is better than an airbrush. Can anyone with experience chime in.
http://www.tptools.com/p/1836,64_Tou...Spray-Gun.html
OR
http://www.tcpglobal.com/airbrushdepot/badger.aspx
Thanks for any help
Sure, a larger gun would work just fine for doing the entire seat. You would probably want to remove the seats to do this. More overspray.
You don't have to spray the stuff, just easier to blend or do a partial seat.
Hey Jerry, I recolored a Classic Grey wheel on my cab, changed it to black. It is holding up very well and looks great.
I used it on the rear portion of the wheel too... the vinyl part. It looks like a black steering wheel.
The only difference when doing vinyl is to not use any sort of petroleum-based product to wipe it down prior to coloring. This is not required anyhow (unless you want to strip exisiting color from the part)... but it will melt the vinyl if you try it.
Old 07-15-2008, 03:20 PM
  #48
Boeing 717
Registered User
Boeing 717's Avatar
THanks alot Mark. My wheel is already black but it has a few marks from rings and such on it and its probably not as black as it used to be. Im gonna give it a try. What product did you use????
Old 07-15-2008, 04:00 PM
  #49
MarkD
MarkD's Avatar
I like surflex... by colorplus
www.colorplus.com
no affiliation, just a customer
Old 07-15-2008, 04:52 PM
  #50
Raptor
Raptor's Avatar
Smiles: Thanks for the update. Towels seem a lot easier and the results look very nice!
Old 07-16-2008, 07:31 PM
  #51
henkinc
henkinc's Avatar
Guys - Dynamix worked fine after I learned to "dab" it on with sponge, not "wipe" it on, which left "brush marks." Anyone want before and after shots, just e-mail me. I don't klnow how te free up storage on the Rennlink site. (Or tell me how, and I'll post them.) They are UK also. Need to clean with methalated spirits (denatured alchohol), then dab on. I had to try 2-3 times to get touch right. Let dry to matte finish, and a day or so later put on the conditioner for lustre and leather smell.
Charlie
Old 07-16-2008, 09:38 PM
  #52
MarkD
MarkD's Avatar
foam brushes also work well and are very easy to use the "dab" technique... fairly dry brush, definitely not wet. Takes a little practice.
Old 07-18-2008, 03:30 PM
  #53
FisterD
FisterD's Avatar
Here's a pic after the dye was applied via airbrush.
Old 07-18-2008, 05:24 PM
  #54
JonT
JonT's Avatar
MarkD/FisterD:
What is that color called, did you order it from Colorplus, if so how, etc etc?
I have the same gray interior. The colorplus site lists classic gray as a stock color but I'm pretty sure that is a much darker gray.
thanks
Jon
94 968, also gray/bule interior
Old 07-18-2008, 07:29 PM
  #55
henkinc
henkinc's Avatar
Darrin - but what is the "before" pix? This is flawless!
Charlie
Old 07-18-2008, 08:13 PM
  #56
Pete Lech
Lifetime Member
Pete Lech's Avatar
Unhappy
If you have black seats, you can buy Auburn brand Leather Dye at motorcycle shops. Made for motorcycle saddlebags and leathers, it works great, and is the right sheen to hide those abraided spots. Put mode conditioner over it once it dries. Used in on my 911s many times.
Wish they made it in Classic Gray for the 993.
It is a shame that Porsche basically spray-paints the leather instead of dying all the way through.
Old 07-18-2008, 08:25 PM
  #57
henkinc
henkinc's Avatar
Dynamix in N Ireland makes many if not all colors for the 993 and many other cars. Google them and check it out.
Old 07-18-2008, 08:47 PM
  #58
autobonrun
autobonrun's Avatar
Default Not Color Plus but the procedure is the same.
This link has additional information including links to the airbrush used.
Before using the airbrush on the leather, I used a piece of cardboard to establish the spray pattern and to determine the optimum thickness of the dye. If I recall, I set the air pressure to the brush at around 40 psi. Again, you can use some cardboard to test various pressures and air brush tips. Usually the brush kit comes with about 3 tips that provide different spray patterns.
http://forums.pelicanparts.com/showthread.php?t=204374
Old 07-19-2008, 10:24 AM
  #59
MarkD
MarkD's Avatar
Originally Posted by JonT
MarkD/FisterD:
thanks
Jon
Jon,
This was not a "stock" color for colorplus. They tend to have the earlier color formulas. I sent them a sample to match (I used a 1" sq swatch from the bottom side of one of the rear seat pads and a piece from behind the seat hinge cover). This is Marble Grey, IIRC, and since I had the match done she should have the formula already documented. If not, I have the info in my paperwork. Shoot me a PM...
I am out of town right now so can't get much done for a bit.
Old 07-19-2008, 12:17 PM
  #60
henkinc
henkinc's Avatar
This is what Dynamix carries (one of two sheets of Porsche) check the other. I don't see the light grey match there, but maybe you can satisfy yourself. (No affiliation)
Charlie
http://www.dynamixdyes.com/porsche_colours2.php
Quick Reply: Don't be afraid to dye your seats!
