911chips
Guest
Posts: n/a
bruce c59...the fact that you got your chip second-hand explains the pinging. When ordering new, Steve Wong asks you what octane to tune for and even what exhaust system you're using. I had his chip in my '89 G50 Carrera and it made a *huge* difference, not just in improved power, but in drivability throughout the power band as well. Wish I could get one for my '96 993.
I had a Autoathourity chip in my 95 it worked great, but didn't work with my Immobilizer, so I picked up Steve's chip.
Really like mid range, really smoothed out the power band, the car totally comes alive after 5000 rpm's.
No pinning at all, up here, but I can get 93, but most of the time it's 92.
Thinking of going for one of these, given that the exchange rate makes on uber-cheap.
Just got a couple of queries though ... on the basis that the best fuel in the US seems to be 93ron, how does Steve get the mapping right for 98ron? (the answer to this may be really obvious, but I have no clue about engine mapping, etc!)
Also, when I did a search on the topic, I saw a couple of comments about the immobiliser light flashing constantly after the chip change - anyone know if this is an issue with Steve's chip?
Cheers
Cheers
"93 ron in us is like 98 ron in europe, the 93 number the us uses is not really ron but a formula of mon and ron."
Per the 993 Porsche manual (WKD 498 621) and the 993 Workshop Manual,
the minimum octane required is a RON = 98 & a MON = 88. In the USA
the retailers, e.g. Shell & Chevron, calculate an octane rating using the
method of octane = (RON + MON) / 2. Using that method, the minimum
octane per Porsche based on USA pump indications is 93.
So here in SoCal those with a 993 and only having access to 91 are running
their engines on a marginal octane. This will result in sub-optimal performance
in some cases, e.g. various loads & temperatures, as the knock sensors will retard
the timing and thereby reduce engine torque. Furthermore, those using the
so called "performance" chips will be even closer to compromising overall
performance and cause a greater probability for pinging.
Bottom line: There's little to no margin available for "pushing the timing"
given Porsche's specified octane requirements.
RL Technical Advisor
Take a quick look at your engine to see if it has the black plastic intake manifold or the aluminum Varioram one.
