993 Forum 1995-1998
Strange problem
Old Mar 5, 2008 | 04:31 PM
Falcondrivr's Avatar
Falcondrivr
Default Strange problem
Hopefully, someone has had this one;
2nd day in a row, I exit the interstate (high speed) portion of my commute and enter surface streets. After the first couple of lights sitting, sitting, then going, when I approach the third or fourth stop, the engine revs when I push in the clutch. While I'm at the light stopped, it revs to ~3K rpm, drops to idle, revs to ~3K rpm, drops to idle, etc... The frequency of the revving is about every 2 seconds, up and down, up and down...It continues until I turn off the ignition. Then I restart the car and it runs normally.
WTF? Anyone, Bueler?
Old Mar 5, 2008 | 04:43 PM
Bruce SEA 993's Avatar
Bruce SEA 993
From: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
ISV Valve? Mebbe it needs cleaning...
Old Mar 5, 2008 | 04:59 PM
Stealth 993's Avatar
Stealth 993
Vacuum leak.
Old Mar 5, 2008 | 11:35 PM
Leander's Avatar
Leander
Lightbulb
Right foot pushing gas pedal perhaps?
Old Mar 6, 2008 | 12:28 PM
Falcondrivr
Thanks for the replies (even the smartass, which I can appreciate.) I had never heard of an ISV until the above post. Did a search and viola!!!!
I just cleaned it really well. It was coked up and seemed to stick a little when I removed it. I'll post a follow up in a few days with the verdict.
Old Mar 11, 2008 | 09:35 PM
Falcondrivr
Just a follow up. Problem seems to be solved! ISV was apparently the issue. Thanks Rennlist!!!
