LWF, which pressure plate, RS or turbo?
Getting ready to go to a LWF and have a question for those who have done it. Which pressure plate did you choose, the standard RS unit or the twin-turbo?
I may do an occasional DE or AX but most driving is street and I'm thinking the lighter pedal pressure of the standard unit might be nicer although for the same cost is the tt unit the smarter way to go. Hmmmm. Pro...Cons?
Thanks!
Thanks!
Good luck. I had the same question last week but no answers. I ended up getting RS parts and not going with the turbo parts. I just wasn't clear on what parts were interchangeable. I think the issue was that the turbo has some sort of assist on the clutch that the NA doesn't have.
I'd buy a kit that provides all the matched parts, they still use pretty much the same parts including the 964RS flywheel, on the 997 GT3RS.
note the 993RS/CS(M003) and 993 Cup were the only ones that came w/ the single mass set up, all the others including 993RS M002 used dual mass.
when I order parts for mine I specified all 964RS parts but i think that they have been supersceded w/ 996 or 997 #s.
I plan to buy a kit that is properly matched but was interested to hear from those that have done this install. Would like to know how much difference or stiffer the clutch pedal feels with the turbo pressure plate vs. the standard RS pressure plate.
After a little research I learned the turbo (the car, not the clutch) comes with a power assist to help ( I believe) with the increased pedal pressure, hence the desire to avoid putting in a pressure plate in my non-turbo car that requies high effort since the na cars don't have the power assist.
The last clutch in my car was a 996 GT3 unit. Worked a treat ... not worked hard either.
BTW: LWF and RS clutch is a great mod for those who didnt get it from new...
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
The RS LWF and clutch is a fine package for the street. It's my understanding that that there are pressure plates and clutch disks that are better suited for track use such as the TT pressure plate and 996 Cup car clutch.
Das macht nichts, use the 964RS or 996GT3 or 997 GT3RS parts
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
RL Technical Advisor
One should be careful about mixing & matching parts,...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
If you don't need the extra clamping force for the street or with a mild engine, using a pressure plate with more clamping force puts more stress on the TOB and crankshaft thrust bearings. Remember, you depress the clutch to start the motor and guess what takes the pressure when the pedal is held down? the center crank bearings.
When some use a thin (0w-40) oil, thats not a recipe good for optimal engine life.
As always, parts selection should be matched to the "mission" as its NOT a one-size-fits-all world.
Viper Bob at Vortex put in his light weight flywheel kit on my C4 with the higher clamping pressure plate. My understanding is the kit contains a RS flywheel and TT pressure plate. The change is awesome and does not require more force to shift than before. I also got a new slave cylinder in the process so maybe I don't know what an "easy" clutch should feel like. The upgrade is a vast improvement and my wife says the car is easier to drive now than it was before the upgrade - go figure. I couldn't be more pleased with the upgrade and Bob and his crew were a pleasure to work with. Good luck with the upgrade, you won't be disappointed.
As always, parts selection should be matched to the "mission" as its NOT a one-size-fits-all world.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I am tempted to go with the tt pressure plate but my car, other than the RSR mufflers is stock hp and it seems based on what Bill and Steve are saying, it seems to make the most sense to go standard RS.
