First proper drive with mods-FINALLY!
With the temp above 10C for the first time since the fall, it was an excellent day to excercise the car properly since installing all the "goodies." All I can say is WOW! The suspension really does transform the car. I found the most difference at the rear of the car; seems to be much more planted. I also found the ride to be quite reasonable even though mine are set towards the stiffer end.
I think my biggest surprise however was how much different the new shifter felt. If someone told me the tranny had been replaced, I'd probably believe them. Funny how the mind works. Really makes me want to get my RS steering wheel on!
The stereo? What can I say. It's great to be able to concentrate on the drive without fiddling with CD's/radio stations all the while listening to your favourite tunes! I'm such a slug when it comes to this stuff.
Hope everyone who's been hiding from the winter gets to enjoy a nice drive soon as well-BRING ON SPRING!
Tim.
I took out the C4 for her first Auto-X (totally stock car), then came home & took out the C4s, & drove her most of the weekend!
Today is nice also, to bad, we will see rain for the next 10 days!!!
Got any pics of the shifter? I've been thinking about changing out the C4's.
I started up the car this evening to check the new starer with the four O2 sensors dangling underneath the car. X-pipes should arrive sometime this week so I continue struggling with all the rusted bolts on the current exhaust - I'll probably end up breaking or cutting them. Also the Ruf wheels should be finished later on this week - curb rash repaired and finished with the new paint and clearcoat. Then the Kinematic Clutch Lever update / bleed the fluid. Brake fluid flush. And many other things on the go.......
Hope to join you on the next drive and check out you're upgrades......
BTW, if any of you locals run across a reasonable deal on a coupe please let me know!
Regards,
Doug
