Help!!!! Trying to remove cats from my 993...
I'm replacing the cats on my 1996 C2 for hi flows. I have removed (snapped) all the bolts and donuts connecting to the muffs and heat exchangers. I thought I was done but now I realize that the heat shields are holding it up.
How do I remove the heat shield or the bolts holding the cats???
I'm at a point of no return as I snapped all the exhaust bolts so it's not like I can put it all together again either. PLEASE HELP!!!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Lefty-loosey -- right? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seriously now -- which bolts are you referring to? The cat to heat exchanger bolts? There are also 1/4 turn fasteners or camloc type of fasteners that require a 6mm wrench to remove. There are five of them IIRC. They attach the cat heat shield to the cat.
Sorry, I wasn't clear which bolts to remove. It is the cat heat shield bolts. I was able to remove 1 of the 1/4 turn fasteners but the rest are a problem to remove due to where they are located. They are difficult to reach. Is there a simpler way to remove them without cutting the heat shield itself?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Use a small 6mm combo wrench --- the closed end typically has a 15 degree bend that will allow you to barely get to the bolt head, very near the bumper cover / heat shielding.
Most of the bolt heads will snap off when removing the cats for the first time. You will need a long cold chisel to knock off some of the weird nuts that the cat bolts connect to. You then will need brand new nuts and bolts to replace the hardware you 'cut' off. YOu might even need a Dremel with those heavy duty, fiber reinforced cut-off wheels - I did. Those tiny bolts on your heat shield will snap off with visegrips. You will see where you might have to buy some 993-specific hardware to replace some weird threaded clips and small miscelllaneous bolts. This is an easy job, it just takes time, a good light, a nice thick piece of cardboard to lay on, a good jack and a fair amount of specific tools to make it come together. How do I know? I have done it twice - on two different 993's!
I usually replace all the bolts with stainless steel ones unless the stock ones are in good shape. Remember, with most alloys stainless is weaker than steel bolts but it seems to work fine with the exhaust system. I also replace all the bolts holding the clamps on the tips and mufflers with SS bolts. It just makes it much easier to service in the future.
As far as the clips that hold the sheilds on, they are weird and I could only source them exactly from Porsche. They are also stupidly expensive (like $10 each). I used standard sheet metal clips and stainless bolts when I did mine...not totally original but much cheaper. The clips will rust regardless unless you can source SS ones.
Oh, I use a air power cut-off tool and cut the bolts off if they resist. Usually the badly corroded ones will just snap off.
Cheers,
Mike
Cheers,
Mike
Success!!!
I was able to get the last rear bolts using the long nose vice grips along worth some choice words. Most of them snapped off but I don't think I’ll need to use them since sport cat pipes will be fitted.
Thanks to everyone’s comments, they helped me along nicely. Now for a nice cold
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
