PerfectPower Strut Brace
#63
Looks like you will need a Allen head wrench or socket for the strut bolts and an open end wrench or spanner for the strut bar.
A note of caution regarding the force to tighten the bolts - the alloy is soft and will only need to be torqued to 10- 15 ft lbs.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#65
Seared
I think the weak link is the top mount stud - these are very easy to snap. The actual strut brace mounts are super beefy.
Andreas
#66
here is a pic[IMG]<a href="http://s5.photobucket.com/albums/y169/JustPondering/?action=view¤t=Photo_040208_002.jpg" target="_blank"><img src="http://i5.photobucket.com/albums/y169/JustPondering/Photo_040208_002.jpg" border="0" alt="Photobucket"></a>[/IMG]
#67
#74
Finally getting around to this install...
Do you put the washer INTO the milled hole in the brace or UNDER the brace (between the shock-tower and the brace)?
How do you figure out how wide/ narrow to make the bar?
#75
Slight tension on the bar. Not enough to move anything, just snug.
