On my '95 993, I have the 17" cup wheels but unfortunately they have some scrapes from a bad encounter in a car wash (never again). I went through while out of town and gee am I sorry. I have been looking for a set of new cup wheels to replace them but have been reading about refinishing them. My mechanic gave me a business card a while back, for a company that comes to you and refinishes them on the spot. Has anyone had good luck with that sort of service. I am sure it would be more reasonable than new ones. Any luck with powder coating wheels and the durability of the finish? Thanks.
I owned an on the car wheel repair company for a while. If the damage is purely cosmetic, than on the car repair is the best bet. It is very simple to repair and blend a lip or other damaged area. The color that Porsche uses on the "Cups" is actually pretty simple to match. I used to do all of our material purchasing from a company called Rightlook (rightlook.com). An airbrush works best with reasonably low pressure dry air (20-30psi.) It is a DIY if you have the right materials. Feel free to mail me with any questions.
I ordered and received a complete wheel refinishing kit from Grinot's Garage. I believe it ran about $60.00. The kit comes with a cleaner to remove wax and silicone tire dressing, a can of zinc primer, two cans of silver wheel paint, and two cans of lacquer clear coat. The kit instructions stated the kit will completely refinish four wheels. The instructions also recommend bead or walnut blasting the wheels before repainting. I don't think I will be able to get that done and will have to rely on sanding and/or steel wool.
My wheels had been painted by the previous owner after a tire installation gone bad and besides the outer edges of the wheels that are chipped, the area inside each lug nut holes needs repainting as well. I would like to refinish all four wheels entirely or as well as I can without removing the tires. A friend recommended only working the bad spots and blending the paint. Any suggestions or guidance on whether or not to go for the Full Monty or just a touch up. Thanks!
Im going the full monty on one of my wheels - Ill let you know how it comes out. The wheel defects and rash were filled, I sanded those down, sanded the entire wheel and primered. I decided to do not only the face but the inside as well.
I will sand the primer down with 600 and start the wurth tonight...
I will have to say that since my last posting, I chickened out and had my wheels done professionally. I initially started sanding on the worst one and found it was not easy to get at the chips near the tire. The company I went with breaks the bead on the tires and does a proper job of sanding and painting everything that can be seen.
My 993 is painted Artic Silver and I decided to have the wheels painted the same color. It will take a little time to get used to but I am happy with the refinish job. It was a touch decision at $125.00 per wheel as opposed to a $60.00 wheel kit.
Here are a few photos of the wheels after being professionally painted. I elected to have them painted Artic Silver as opposed to silver. I also picked up some permanent enamel paint and repainted the center caps. So far I am very pleased with the results. Happy Holidays my friends!
Super Moderator Needs More Cowbell Lifetime Rennlist Member
If you have hollow spokes, make sure the wheel refinisher puts a plug into the valve stem hole during the sandblast (or equiv) process.
There was an interesting thread on Rennlist about a wheel that would not balance after refinishing....turns out the wheel was full of sand.....once emptied, it balanced perfectly.
Thanks for the tip on the balancing problem inherent with sand blasting. Believe it or not, the whole process is done in an all equipped truck that arrives at your house. The truck is equipped with a device to drop the tire from the front wheel surface, a paint booth and heat lamps for baking the final product. I don't believe there was any sand or bead blasting done. Just hand sanding and putty as necessary. I had no curb rash for putty so I believe only sanding was required. Not cheap but truly a professional product.
I returned the refinishing kit I purchased just before Christmas. Definitely not cheaper but I believe the final product is better!
Looks great!! Im in the process of finishing up the full monty on all 4 of my wheels. I filled all the rash and tire install defects from the past 13 years. I decided to go urethane as a clear coat versus the wurth enamel. I did not think the enamel finish is not as thick and as factory looking as the urethane. See Springers comments in this link:
