RS Question.....
Link to movies is as jdistefa's post, roughly in reverse date order from the run in of this year's speed championship. The top one will be of interest to you Jean, it's from an end-of-season sprint at Anglesey circuit in N. Wales, my first time there on the brand new circuit - look out for the woeful 4th-5th gearchange on the back straight where I'm not sure I got 5th so took it out again to check! (mental note: must fit solid engine mounts and stiffer gearbox mounts for 2008).
In front there are
3 different side members; 993, 993RS&tt, GT2 uses a 964 part here
3 different A arms; 993&tt, 993RS, GT2 differences are in the bushes
2 different wheel carriers; 993&993tt, 993RS & GT2
4 different basic spring/shock packages(not counting US versions); 993(Boge & Monroe) , M030 & 993tt(Boge & Monroe), 993RS Bilstein, GT2(numerous variations)
5 different stabilizer packages; 993 21mm, M030& tt 22mm, M491 20mm, RS 23mm, GT2 24mm
In back there are
2 different crossmembers; 993 & RS, 993tt & GT2
3 different side panals:993 & tt, 993RS, GT2
4 different A arms 993&tt, 993RS(2 versions) >2, GT2 uniball, differences are in the bushes
3 different toe links;993 & tt & RS,GT2, GT2 w/ uniball
4 different kinematic links; 993early, 993 late&tt, 993RS & GT2, GT2 w/ uniball ,differences are in the bushes
4 different camber links; MY94& GT2, MY95, My96, GT2 w/ uniball
2 different sub fram mounts; 993 & tt & RS, GT2
5 different stabilizers; 993 18mm, M030 & M495 20mm, tt 21mm, RS & GT2 20mm, GT2 22mm
spring and shock packages to match the front
