Carnewal cold air intake
Yup... I've got it and it works great. As for the MS airbox, it fits. In order to install it on the MS airbox, you need to remove the plastic chrome piece. The new cold air intake fits into the exact same tabs as the MS airbox. I have the MS airbox cover with the cold air intake... cool high pitch sound at wot.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
with my fixed Aero Kit 1 tail. This snorkel intake originates with the 993 TT car, with a fixed tail. Prior I had the Motorsound airbox. I reinstalled the stock airbox, popped in the snorkel and sold off the Motorsound.
What the snorkel, the VarioRam 5,000 RPM intake induction sound gets bit muted...you can still hear it but not as loud. It is pulling in ambient air, not heated engine compartment air...see Robin Sun's article as mentioned earlier.
But you will need a fixed tail...by the way, I may be selling my Getty Design 993RS tail, painted GP white, with grill, in super condition...I have not decided yet. The tail cost me about $550 + finish and paint...I'd consider offers over ?????
Maybe I'll keep it....
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
chuck
Bringing this thread back from the dead. Am I right thinking that a motorsound airbox used with the cold air intake will suck hot air from the engine compartment through the drilled holes AND cold air through the snorkel? Thus would the effect of the snorkel be increased if it was used with a standard non-drilled airbox cover? And Eric, is yours still for sale?
Ok it makes sense.. However on Gert's site it says that it will work with the motorsound airbox.. I guess it will but probably the effect will be weakened. Eventhough you use the snorkel with the std. airbox the effect in increased hp might be marginal at best?? Anyone?? I also wonder how it will affect that wonderful aircooled sound?
There's definitely no increase in hp with this. You don't really get substantially cooler air when you're at speed, and you add a little bit of air restriction. So you lose a bit of power if anything. (I did some data logged runs to confirm that)
But yes, it works with both the standard and motorsound airboxes.
I tried it many years ago and i did not like the sound and it felt like i lost some HP. i also had the motorsound airbox at the time. The snorkel i believe is for the turbo pcars and is needed to pass through the intercooler to get fresh air.
