993 Forum 1995-1998
Immobilizer Remote Range Sucks!!!
Old Oct 17, 2007 | 10:16 AM
richardew's Avatar
richardew
R.I.P
We have two remotes. Mine works well at six feet-the wife's works at what she says is ten feet. Differing methods of measuring I'm sure!
Doesn't that usually work the other way around?
Actually, the range is extended if you hold the remote to your chin. Really. Try it yourself.
Old Oct 17, 2007 | 10:25 AM
Terry Adams's Avatar
Terry Adams
Veteran: Army
42' (Arena Red wide body). Slightly more in a church parking lot.
Old Oct 17, 2007 | 10:39 AM
99three's Avatar
99three
2 ft if I'm walking towards it...almost 3 ft if I'm running towards it really really fast.
Old Oct 17, 2007 | 12:34 PM
Falcondrivr's Avatar
Falcondrivr
~ 10 ft. with a fresh battery.
Old Oct 17, 2007 | 01:52 PM
gordo993's Avatar
gordo993
Mine works best if I point it at the driver's side headlight from about a foot away. And yes, I only have one...
Old Oct 17, 2007 | 01:53 PM
tbil's Avatar
tbil
Not much more than 3 ft, even with new battery. Might gain an extra foot at the side windows or directly of the bow. It is a pain....
Think of it as a secruity feature - Thief cant sit in a parking lot with a device to see which cars unlock as you transmit a signal.
Old Oct 17, 2007 | 02:36 PM
tmc's Avatar
tmc
The 996's had a TSB about this.
In a nutshell, the antenna for the cars was designed for a different frequency (one that was OK in Europe) than what is used in the US.
According to the TSB, you:
1) Cut off 100mm from the antenna lead
2) Remove 130mm of shielding from the remaining antenna lead (note that's USA specific)
(See TSB 911 (996) 7/04 9662 Binder 9 - Electrical)
Unfortunately I don't see a similar TSB for the 993 (see list here https://rennlist.com/forums/993-forum/338398-porsche-993-technical-service-bullitens-tsb-s-updated-regularly.html)
tmc
tmc
Old Oct 17, 2007 | 02:44 PM
Stealth 993's Avatar
Stealth 993
So where is the antenna located on the car?
Old Oct 17, 2007 | 03:38 PM
993C4Smontreal's Avatar
993C4Smontreal
for those of you who did the key fob mod away from the switchbalde.....do u sometimes have to "tap" the fob to get it to work and get the red light to work when pressing it?
Old Oct 17, 2007 | 07:04 PM
Kigiin's Avatar
Kigiin
I have two fobs, each with new batteries. One works only at less than 10 feet (usually less) and the other works well out to 30-40 feet (sometime more).
Why?
Old Oct 17, 2007 | 07:26 PM
TRINITONY's Avatar
TRINITONY
Why?
Thank you! And they didn't believe when I said at least 40 feet...see cabrio...
Old Oct 17, 2007 | 08:08 PM
Guy's Avatar
Guy
I get at least 30 feet.....not sure where the antenna is but never had a problem with either remote
Old Oct 17, 2007 | 10:40 PM
baja272's Avatar
baja272
3 feet away on a good day, I have both remotes with fresh batteries and additional batteries in the door compartment, why you ask? the spare batteries are a lesson learned after a tow truck had to bring my wife and I home from a Sunday drive through the country side.(very expensive lesson).
Old Oct 18, 2007 | 03:38 AM
Tour18's Avatar
Tour18
Hey, this isn't fair. Mine only work from about six inches.
Old Oct 18, 2007 | 08:47 AM
cabrio993's Avatar
cabrio993
yeah...yeah...right! I'm sure you paid him to say that.
