Immobilizer Remote Range Sucks!!!
I did lots of searches and posted on this several months ago. Someone mentioned an antenna under the passenger seat but I wasn't able to locate it.
Mine works at about 2-3 feet max. As if that's not annoying enough, I often have to press it several times even if held right up to the door or sitting in the car. And yes, I have replaced the batteries.
My new key fob battery from a Porsche dealer = $18.35
Standing in the pouring rain next to your shiny Porsche getting drenched, pressing away like an obsessed monkey wondering why the new battery didn't help, while onlookers stare and wonder how someone who could afford a Porsche is not technically competent enough to operate a key fob.....
PRICELESS!!!
One would think that with all the expertise on this board, someone would have found a technical mod/fix for this widespread problem by now. Maybe we should pass the hat and set up a prize for the guy who comes up with it!
PRICELESS!!!
-Chris
Okay, try this - and it is not a joke. As you are approaching your car hold the fob against your chin and push the button...................You have to act like you are scratching your chin so that you don't look too looney.................but it works. Read about this in another post years and years ago. A friend of my was complaining about the short distance and I showed her this trick and she was amazed. Turned her whole body into a high powered antena. Usually I have to be about 5-6 feet away, but using the whole body antena method I'm good from 20-25 feet! Not great by any means but good old yankee injunuity. Probably didn't spell that right..............
OK I don't know if this is an urban myth, but someone once told me that there's some truth to the notion that putting a car remote to your chin and pressing it increases the range. Something about how your cranium acts as sort of a echo chamber and magnifies the signal. Who knows.
Guys, what does it matter, no matter how far you are away when the remote works, you cant open the door until you are next to the car!!!....For ref mine works at 10-20 feet, but I seldom use it until I am close to the car....no point
Someone must know where the antenna is and figure a way to get it to work better. I noticed a lot of the replies are from the northwest. We're heading into the perpetual rainy season (as opposed to often rainy) and folks are looking for a way to spend a little less time in the rain. I'm not too concerned when walking up to the car, becuase you obviously can't open the door until you are there, but as soon as I get out, I'd like to start walking away but can't risk getting more than a foot away from the door while pressing multiple times and then resort to the remote-to-the-chin thing. I've heard theories on touching the remote to your chin. It may also be the orientation. Most people aim the remote like it will emit a beam out the key. Try holding the key straight up while pressing the button.
I've noticed that my transmitters work better if I hold them up above the door body when I push the button. My guess is that the receiving antenna is inside the car and the signal goes through the glass easier than the metal. Holding the transmitter at your chin may give it a better shot through the glass as opposed to holding at waist height where the signal has to go through the door.
The immobilzer control unit is located under the left seat next to the DME. There is no extra antenna cable that is running out of the control unit. Look at the picture to see an open unit. On the left top side you can see the antenna design copper field. It may be different for other frequencies.
BTW, the guy who made this layout should be fired...
The control units housing is made from plastic and the metal cover has one or two holes (upper mid area near th red switch in the image below). This holes are very important for the range I think. Maybe someone can test the remote control range with metal cover removed and post the results...
PDriver
PDriver
, if I could only program the other two ..
