What weight oil do you guys run in your 993? (with hydraulic cams that is)
#31
I might try to run the Brad Penn 0w30 this winter and watch the oil pressures, as it has a higher HTHS than m1 0w40. I'm due for an oil change anyways in the 964.
#35
Huge variation in grades used, even between cars that are in same climates (assuming the grade is used year round). A few in Canada running 15W and higher, and I can only assume it gets freekin' cold up there.
#39
#40
#41
RL Technical Advisor
Its OK, albeit somewhat expensive. As long as one is willing to change it often enough, I have no problem with their product but I take issue with any recommendations that a high-end synthetic can be used for extended drain intervals as a cost-saving measure.
IMHO, its FAR better to use a good product like B-P or Swepco and change it a lot, compared to using a high-end synthetic for 10K+ miles.
#42
1 Post
Steve: what drain interval do you recommend for a street only 993, driven mostly around town, avg speed 45mph, 30-40 minutes each trip?
#43
In the Targa M1 0w40, the race car 15w50 redline. But I have been looking at switching to something else.
#44
5W-40 syn ...
With the previous 15W-50 syn, consumption was ~1.5l/4500mi: switching to the 5W-40, I haven't added more than 1/2l in 4500 mi. Cannot explain - but will not complain either
#45
