Does going from 17in to 18in wheels reduce braking power?
I recently switched out my 17in wheels for a set of porsche 18in wheels and tires. Since installing the 18s, it feels like my braking power is now reduced. I know 18s are heavier wheels and tires, does this effect the braking ability?
thanks
thanks
I once filled a friends bike tires with water as a gag... That baby had braking problems!
The 18 wheels may have more rotational intertia, but that small difference should not be perceivable.
The overall diameter should be about the same between the two wheels. That is all that matters.
Pete
Pete
Weathergirl
Given that an 18" tire will have a wider and shorter contact patch, that makes sense.
But likely it's what Pete said--you probably picked up 5lbs of unsprung, rotating mass per corner and you're feeling it.
18" gave you a wider tire patch...better for breaking. Breaking is a lot about tires. If the tires you ran on the 17" and the 18" were the same, breaking should be better with the 18"...assuming the same break pads.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Martin, I think you mean "brake" not break....
I agree with you, it is probably a difference in tire compound or age. Everything else being the same the 18's should be better.
Braking power is the same but, you are now braking more weight and that weight is pushed out further from the axis. So, you will need more pedal pressure to stop the car. That doesn't mean the brakes aren't up to the task. And, if you have a larger or stickier contact patch with the new tires, your braking distances could actually be shorter but - you'll have to push harder on the center pedal than you used to.
Larger wheels almost always weigh more and they push that weight further from the axis (center) where it is more difficult to stop. These rules (of physics) also apply to acceleration so don't be surprised if your car feels like it's not as quick as it used to be.
MC
MC
In short - there is virtually no performance advantage to running larger wheels unless they allow a larger tire contact patch. Even then, is it worth losing acceleration, braking performance and steering feel to run a larger wheel/tire combo? Only, if the looks are more important than performance.
I've written extensively about this on the 997 forum. I took the 19" wheels off my 997 and put 18" carbon fiber/magnesium wheels on it. The effect is very noticeable, feeling very similar to a lightweight flywheel. The car accelerates more quickly, brakes shorter with less pedal effort and has lighter steering feel.
https://rennlist.com/forums/showthre...ighlight=dymag
MC
I'm Still Jenny
Very interesting. I wasn't sure if the lateral rotation (vertical axis) of the wheels would be affected by the forward/backward rotation of the wheel. The side to side (about the lateral axis) would definitely be affected. Thanks for the info, those Dymag wheels are gorgeous!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
What are the tires you have on the new wheels and the old? Are their treadwear ratings similar? Condition similar?
I feel rubber to be the most significant variable here.
Is the braking differences you feel on-track? On street?
The tires i have on my 18s are a little bigger in overall diameter than my old setup on 17s. I am using the tires that came with the 18s take-offs, they are 235/40/18 fronts, and 265/40/18 in back. that could be playing a role in my problem, i assume. I am also feeling that it has effected my low speed steering some too. the steering seems a little vague at low speeds. i really dig the way my 18s look, but i am not fond of all these sacrifrices; braking, steering and bumpiness...
Hmm, I pronounce forte: "Forty" but, yo, its easier to rhyme with when Im spittin' out some dope hip hop lyrics homey...
I been seein dat different tires -even da same size
can affect my steering turn-in wize,
But, yo, on suspensions, I ain't no master
can you fix 'dis sh*t by f*ckin' wid da caster?
