Collar for TRG sway BARS?
For both front and rear I have mine on the outsides. Get then snug - l/r movement is what you want to avoid. Then I painted a stripe so I can quickly see if it rotates.
Don
Your suspension is absloutley beautiful!!! I think we actually spoke about this once.I was reading Jeff's DIY on upgrading the suspension and I noticed that he mentions with the stock type sway bars with the collars welded on ,that the collars are on the {Inside} of the bushings.This got me thinking,that I have my TRG collars on the wrong sides Is this correct for a stock Porsche Turbo Bars or RS bars that the welded collar is on the inside and the TRG bolt on collars are on the outside?Any pictures appreciated
RL Technical Advisor
We always installed those collars on the inside.
A note,.....welding collars on a factory or aftermarket bar destroys the heat treating that these undergo and they can fracture without warning.
Steve
Thanks for responding .So let me get this straight, the TRG collars mount on the {inside} of the bushings?And with say a stock Porsche Bar with collars welded on from the factory,they also are on the {inside} of the bushings?Is this correct?
Yessir,...that is correct.
Made me walk out into the garage and peek. Yup, rears are on the outside, and if my memory serves, I seem to remember a problem getting the bushings and collars to fit, but I could be all wet on that one. Next time I play with the suspension (right now I'm in leave well enough alone mode) I'll look into swapping. Now that I think about how hard it is to get in there to check tightness of the allen head bolts, I'd bet my fronts are on the inside.
Interesting. I'm running the RS droplinks in the rear but those look, longer. I wonder if there is a short/long version or if the ones sent to me by TRG as not the RS drop links? Maybe the length looks different due to angle/obstruction. I doubt that I still have my original P/N. The one's I'm most concerned with, are the fronts. The stock ones are wacky-long and the ends of the stock bars turn down at the the very end making them measure out to be too long for the TRG's front.
THX!!
THX!!
