993 Forum 1995-1998
Need Help Programming Remote with Short Method!
Old Aug 8, 2007 | 01:07 AM
Sonic dB's Avatar
Sonic dB
Default Need Help Programming Remote with Short Method!
This is an edit to my original posting.
I received the $145 remote today... however the programming
method as described below by Rally Jon does not seem to work on my
car.
First of all, my "remote" symol in the clock is a "steering wheel" symbol
I have Silver Guages... would this still be the same as the remote symbol??
Secondly, the "flashing after 15 seconds" bit does not occur. What happens
is that the Steering Wheel symbol lights up and goes off 1 time at about
15 seconds then comes back on again and stays lit.
In any event...this programming method is not working does anyone
have any suggestions? I am following it to a T... please help me avoid
paying a few hundred dollars for this BS work.
Thx.
Sonic
Old Aug 8, 2007 | 04:28 AM
24FPS's Avatar
24FPS
Old Aug 8, 2007 | 01:32 PM
Laura's Avatar
Laura
New remote housing retail is aprrox. $130.00 Programming maybe 10 minutes.
Old Aug 8, 2007 | 01:35 PM
TRINITONY's Avatar
TRINITONY
10 minutes I have two that need programming; let me know when you're coming east.
Old Aug 8, 2007 | 01:36 PM
TRINITONY's Avatar
TRINITONY
Originally Posted by 24FPS
nice avatar.
Old Aug 8, 2007 | 02:37 PM
Amfab's Avatar
Amfab
What is the procedure for programming in 10 minutes?
Old Aug 8, 2007 | 02:51 PM
RallyJon's Avatar
RallyJon
Weathergirl
From another thread. Foolproof programming in less than 10 min:
Originally Posted by hoggel
This is what worked for me after I fixed the two different problems with my alarm (plagiarized from the repair manual):
1. Unlock the car with the remote and wait at least 3 minutes for the immobilizer to prime.
2. Switch the ignition on. The warning light (looks like a remote symbol) in the clock will go on and then off after 15 seconds.
3. Switch the ignition off and on again within 5 seconds. The warning light in the clock will light up and start to flash after 15 seconds.
4. Start to enter the key code within 5 seconds. Enter the code by turning the key off-on for each digit of the code. Wait for the warning light in the clock to come back on between each digit of the code. For example: 1302
1 = ignition off-on
wait for warning light to come on
3 = ignition off-on, off-on, off-on
0= ignition off-on (10 times)
2=ignition off-on, off-on
5. If the number was entered correctly the warning light will flash after the last digit is entered. When the light is flashing the remote can be programmed and MUST be programmed within one minute.
6. Press the button on the remote until the LED of the alarm system flashes. Operate all the remotes one after the other, wait for the LED to flash after each.
7. When all of the remotes are programmed (no more than 4) switch the ignition off.
Old Aug 8, 2007 | 02:56 PM
RallyJon's Avatar
RallyJon
Weathergirl
Originally Posted by Sonic dB
i mean, reading the technique where it takes you like 51 minutes
to program a new remote by yourself...you need a stopwatch and be in
an empty field somewhere with a 6 pack (or a soundproof garage) to even try and attempt it yourself.. grr
Do you have a very early '95 with the '94 style immobilizer? If you're not one of those few, ignore all that crap on p-car.com and read down to the bottom of the DIY page. Or just read your owners manual--the procedure is VERY simple and spelled out right there in the proverbial FM.
Old Aug 8, 2007 | 04:52 PM
RallyJon's Avatar
RallyJon
Weathergirl
Yes, I've done it several times (had a brand new remote fail after a couple of months). Works perfectly.
Old Aug 8, 2007 | 05:02 PM
Amfab's Avatar
Amfab
Thanks Jon
Old Aug 8, 2007 | 07:22 PM
Sonic dB's Avatar
Sonic dB
Bump per top see new message at start of thread...thank you
Old Aug 14, 2007 | 09:27 PM
Sonic dB's Avatar
Sonic dB
car.
Thx.
Sonic
Old Aug 15, 2007 | 10:22 AM
Flying Finn's Avatar
Flying Finn
King of Cool
From where do you get the code (I've lost mine)? Calling to a dealer with VIN?
Old Aug 15, 2007 | 01:50 PM
coltj's Avatar
coltj
Yup, I got my radio and immobilizer codes from a dealer(Clair outside Boston) in about 3 minutes. They were most accomodating even though I don't use them for service.
Old Aug 15, 2007 | 03:10 PM
Flying Finn
King of Cool
Thanks.
