Anybody pndered a poor man's cold air intake for the unblown masses???
#31
Originally Posted by Peter R.
Liquids like H2O, being sort of kind of incompressible, may have a somewhat detrimental effect
#32
in my (much) younger years, working as a gas station mechanic, we used to use a spray bottle to mist an open carb on grandma's buick to blow the carbon out... vrooomm.... cough cough cough... *black smoke* cough cough...
All part of the overall tune up. lol
#33
That's why an engine that is 'running' when suddenly introduced to water, as in submersion, will instantly bend the rods on the compression stroke as it instantly stops. NOw I'm getting out...
#34
Yes, it is a matter of volume Marlon. A mist will not do damage... though there are many variables to consider.
A more immediate concern would be chunks of built up carbon breaking loose and damaging valve seats or pistons. You only get build up like that with very sedate driving over a long period of time.
If you stick a garden hose in the intake, yeah, you might have a problem.
Have a nice day.
#37
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Have a nice day.
Have a nice day.
Anyhow, some cars still ran, but were never claimed. So, we got to blow 'em up Most of these cars were worn out, nice a loose. So just dropping a brick on the throttle wouldnt do it, believe it or not. They would just ring away at the edge of valve float (these were cars before fuel injection and rev limiters).
One day we got the bright idea of trying to hydrolock one of these suckers. A Honda accord, older model. Got the engine running at full song, nice and hot -- then stuck a garden hose down its throat and turned on the water.... All it did was drown the engine and kill it -- no hydrolock
We figured it was atomizing the water faster than it was taking it in. We pulled the plugs and pumped the hot water out. Plugs back in, fired it up and tried it again. No luck in blowing this thing up with the garden hose
In the end, we gave up and resorted to what we always had to do, drain the damn oil and let her seize..
#40
Technical Guru
Originally Posted by AOW162435
I'm not sure how this snorkle would work on the Turbo...
The big issue is "Does the Porshce p/n snorkle actually 'choke' the cold air flow with a 993 automated spoiler set up"?
#41
Originally Posted by JasonAndreas
It allows the engine to pull air in from above the intercooler rather than through the it.
With an automated spoiler I don't think the snorkel will fit?
Yes - it is too tall to fit under the contour of the deck lid, but I am going to mod the snorkel anyway. Widen it as much as feasible while it is being 'shortened'. This would be an easily reversible mod, since the existing air box snorkel inlet just unsnaps from the main air box lid. If it does not work, snap the original part back into the air box lid.
BTW: I would 'think' that with an intact air box there should be plenty of dwell air for the engine to never be 'choked' for sufficient air volume even if the snorkel does introduce a 90 deg bend in the path. If this snorkel was designed for a heavy breathing engine to begin with, how is it that a lighter breathing, naturally aspirated engine be 'choked' by it???
I f I can come up with a workable and simple design, the next step would be to dyno it to prove it works (pipe dream). If it works, have a mom & pop plastics company make one or two (two pipe dreams).
I ordered a snorkel from Sunset for 42 bucks - last one in stock.
#42
Seared
Take it one step further - go to Home Depot and pick up a length of 4" diameter aluminum dryer venting. Form it around the snorkle end and then gently arc and stretch the hose until it terminates at the top edge of the windshield. Attach the hose to the roof by whatever means you feel appropriate and go drive. True ram air!
Andreas
Andreas
#44
...I f I can come up with a workable and simple design, the next step would be to dyno it to prove it works (pipe dream). If it works, have a mom & pop plastics company make one or two (two pipe dreams).
#45
Marlon,
I have that snorkel on my car with the regular deck lid. The spoiler gear/sprocket mechanism interferes with the snorkel. You have to trim away about half the snorkel in order for it to fit.
I can take a pic of what i had to do to mine to make it fit.
