RoW sport versus RS + 10 mm
I'm trying to decide on suspension heights. 18 inch wheels, 1996 993.
I do about 50% track and 50% fast street, out in the mountains.
I do no commuting at all and I'm not really interested in a smooth ride, I can put up with a bit of bang and crash.
Looking to get the Bilstein HDs and the M030 (actually might get the RS sways instead form what I've read on the boards) and need to know if that 10 mm difference makes any difference on track or not. Thanks.
I put mine about one MM below the bottom of the ROW Sport range, which is the same thing as RS+9. It works well on the street without getting into the whole "bump steer" issue or the rear sway hitting the lower suspension arm. I think you'll find that most end up right around there or 2 to 5 mm higher than mine, although some test their luck at RS+5.
Are you guys getting these cars corner balanced? I had my car set at ROW030 exactly and after my alignment guy was done with the car, the drivers side is 1/4" to 3/8" higher than the passenger side. I guess I'm saying that getting it down to the mm might be a bit overkill in the real world.
Greg H.
Greg H.
Greg H.
Greg H.
I just got mine aligned at RS + 5mm. I only added the 5mm because I use the car as a daily, but if I was using it as you plan to, I'd stick with RS. No bump steer issues at my height and 10mm does make a difference.
If I was doing that much track work, I'd look to get PSS9's which have adjustable damper settings. Alan from Aceparts has these on his turbo and by all accounts, it makes for a very fast car on the track and still usable on the road.
