Recent SAI fix that so far has not worked
Rationale......if the air cannot get to the O2 sensors via the exhaust port, bypass the exhaust port and intoduce the air to the exhaust system as near to the exhaust port as possible. This should then satisfy the O2 sensors!
Remove air box. Detatch the rubber hose off the top of the SAI one way valve, leave this one way valve in place. Insert a new one way valve into the now open hose from the SAI air pump. From the underside of the new one way valve run a hose (I used Goodyear heater hose ID 1/2") out under where the air box will be, and out over the top of the fan housing. Cut hose to length so that it sits ontop of the fan housing but not stick out over it. Now insert an OD 1/2" "t" piece in the end of this tube. Replace air box.
Remove the heat exchangers (HE) and weld a nut (I used a Stainless Steel one) onto the top of flat piece just prior to where it connects to the tubing leading to the CATS....do to each HE, then drill hole in the heat HE exit pipe through the center of the nut. I then used a piece of stainless steel tubing, ID 1/4", OD 1/2" that was threaded to fit the nut and was about 1" proud when screwed into the nut. Obtain some aluminum tubing, about 12" with ID 1/2" and this should slide over the SS tube screwed into the HE. I used aluminum as I thought there would be less heat transfer up the length of the tube and it would be easier to bend.
If you now look up from under the car from where the HEs were towards where the light clusters are you will see two alumium discs which are just covers for two holes in the sheet metal, remove these two discs, they just pop out. Now remove the aluminum pipe from the SS adapter and replace the heat exchanger on the car. Now came some of the fiddle, you have to deliver the aluminum pipe through the hole in the sheet metal (the ones where you remove the aluminum discs from) to the SS adapter screwed into the nut in the HE....you may have to do some bending here but it is quite easy to do just a fiddle to get the right minor bends. Once you have done this you clamp the aluminum tube onto the SSadapter to make an airtight seal....I did this by using a little exhaust repair tape around the seal and then clamping.
On the top of the aluminum pipe attach more heater hose and clamp, run the hose up to the "t" then cut to length and attach to the "t". I then used black ties to hold the whole thing in place and wow it looks semi professional.......if only it had worked.....anybody have any idea why this did not work????
When you say "...if only it had worked..." what do you mean. Did you reset the ODE-II codes? How long afterwards did the CEL light return? Is the new code for banks 1-3 or 4-6?
My wrench and I are going to do basically the same thing next week. We're installing a new SAI valve, and then come off that with a "T" off the valve, and plug the hole that directed the gases through the heads. We then going to run use heat resistant tubing of 1/4" ID or less and run it along the metal trays on the side of the engine, and then near the back of th engine install a 90 degree exiting to the underside of the vehicle. From there are procedures are similar.
It may be that the ID of the tube is too large, thus limiting the pressure.
Yes I reset the codes and ran the car as per nornal, the codes for SAI reappeared as per normal, exactly as they did prior to the "fix", within 100 miles. Yes I wondered about the ID and its ability to delivery the air with sufficient pressure, let me know how yours goes. Where are you planing to egress into the exhaust system? What heat resistant tubing are you going to use?
1 Post
Seems there are 2 main variables to consider (FWIW. I'm not a trained engineer) .
1. The volume of air delivered by the new plumbing - is it reduced any significant amount?
2. The location of the air injection. Note where the original air injection ports are in relation to the exhaust valves -- how does this proximity impact the parameters that the OBDII is monitoring?
Dan
Thanks for the reply....yes I had thought about the volume....when I did the flush I looked at the holes that exit into the port and just sort of guessed that a 1/2" pipe would deliver about the same amount as all those together, maybe thats too big a pipe and I need to go to 1/4"....as to the proximity to the exhuast port itself, that is a good question....I just got as near as I could...the attached pic shows where I welded the nut for the injection of air.....that was about as close as I could get
David, I took your problem to my wrench and we discussed your situation. First, we think your pipe is too large. We're going to to use 1/8 or 3/16. Look at the passages in the heads, there between 1/8 and 3/16, we did measure them exactly. Secondly, did you replace you SAI valve. It could be defecitive.
Just some thoughts. As I said I'm doing mine on next Tuesday...I'll keep you informed.
Originally Posted by ppressle
Why would too large a pipe be an issue? Same volume of air would flow through albiet at a lower velocity.
I guess you might need a little more pumping to get the larger volume pipe "up to pressure" to match the exhaust system pressure, but the pump should be putting out the correct pressure. Difference would be only the amount needed to pressurize the volume of the pipe. After that it should just be the same volume of air getting to the cat which would cause it to heat up at the same rate. yes?
That should work...I am not sure why. Do you have a OBD-II reader that can monitor the O2 voltages? You can tell if the pump is affecting the O2 sensors that way. You know you should see a lean condition on the O2 sensors when the pump is running.
I was playing with exactly the same idea so I am glad you have tried it. Have you considered using the O2 sensor test holes on the CAT as air injection spots? This way you don't have to weld in anything but it will requiire a bit of custom machining to make a custom fitting since these holes are fairly small (like M8...I did not measure them). They also might not be large enough to deliver the air needed.
Your pipe might be the wrong size. The passages in the cam carriers are really small and long so that would restrict the air quite a bit. You certainly can restrict the rubber hose with a clamp and try again. I doubt if the air pump is tuned that closely.
There is also a shut off valve before the pump (at least that is what I think it is). If you pull the hose off before your Al pipe can you feel the air being pumped to confirm that is working correctly?
Good work so far though...I was thinking this would be a cool product to sell to 993 owners except for the EPA liablities...
Cheers,
Mike
Cheers,
Mike
Too much air injected would be my guess as well - stick a (control) valve in the line, or pinch the tube off as Mike noted. The SAI pump is now running into less head/restriction than previously, so is delivering more mass .... and is likely drawing less amperage: I do not know if the latter is a measured parameter in the 993 ECU ... but it appears to be in a similarly balles-up
SAI system I'm playing with
on our Passat 1.8 Turbo.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Thanks for all the input guys....I will test with small ID tubing and see if that works....the pump is running, I can hear it. Only have an Actron reader that detects faults so cannot measure O2 readings....its so frustrating as I thought I had it licked!!!
