DAS Roll Bar install instructions-anyone have them?
#33
Super Duper Moderator
Mine slipped in with only a little torqueing and swearing - no jacks or straps (hmm...that could have really rude implications
The last bolt was a challenge so I used a longer cheater bolt at the left rear seatbelt hole to pull the bar into place then removed that bolt and put the correct, shorter one in.
I did not Dremel a notch, I just reefed the bolt tight to hold the seat belt retractor vertical. All my interior is back in too besides the seatbacks.
Marc
p.s. The included instructions are pretty crappy.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Marc
#34
Agent Orange
I'm with Marc - no problems to write home about. Just take your time and you'll be alright. It's not a huge technical challenge. And don't let your seat belts retract all the way, it can be costly
#38
Beautiful seats! I will let you all know how my install goes and will probably seek advice during the install. Just purchased a used DAS bar from Hutch, plan to have it powder coated white and then tackle the job. Still looking for a set of race seats to go with it.
#39
If the seat belt retracts too far, install the belt unit in a vise pointing up. Wait for a second and then the belt should free up. Once it is out, put a clip of some sort on it to prevent retraction. It is almost impossible to hold it still enough to do this by hand. (Credit for this tip needs to go to Viper Bob.)
Pete
Pete
#40
Pete
Pete
#41
Let me know when you're ready to pull the trigger on those Recaros.. I'm probably going to order them in 2 weeks.
#42
I'm holding you accountable when the divorce papers are served!
#43
Sorry, Can't wait that long Road Atlanta is requiring harness supported seats on the track (if you have harnesses). First DE is in January.
#44
#45
