Fuel Tank level for the track?
Just fill 'er up before arriving and don't worry about it. A full tank should get you through 4 sessions. If you want to obsess about minimizing weight, you could always run low and refill after every single session, but that would be pretty silly.
I haven't really found fuel level to be a significant factor in my handling or lap times. And even if it were, so what... this is just DE.
Yup, it's just a DE, so don't worry about trying to run a lighter load. I've run some of my best lap times with a nearly full tank. In practice sessions for a race, I try to fill the tank up. Having to refule after every session is just needless work.
Also, the fuel guage tends to jump around on the track. Sometimes my light comes on when I still have 1/4 tank. Now that I know, it isn't a big deal. However, having the light come on is an unnecessary distraction.
Originally Posted by Geoffrey
The car will tend to understeer more with less fuel. It is noticable.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
There is also the notion of a half full tank having the most amount of slosh providing one with a dead-blow hammer effect. Cars with rear mounted tanks are most effected like that of a 1985 C4 Corvette I once had. Later years C4 vettes had a mid tank baffle installed that helped the tail-wag syndrome. Probably not that much of an issue with a 911, however.
I didn't have this problem w/ RA-1, but w/ Hoosiers my DL-1 is recording up to 1.5 g spikes on some turns, so from now on I start on full and fill again once I get close to 1/4.
Still plays with cars.
Interesting - I have found that a full tank increases lap times. The difference between a quarter tank (enough for one session) and a full tank is probably and extra 75 lbs.
