This are the sizes that are available, what combination would be best? ( New Tires are 225/40 and 265/35 zr 18 Yokohama AVS sport)
08,0J x 18 ET 52
08,5J x 18 ET 33
08,5J x 18 ET 46
09,0J x 18 ET 52
0 9,0J x 18 ET 40
0 9,0J x 18 ET 27
10,0J x 18 ET 40
10,0J x 18 ET 52
10,5J x 18 ET 47
11,0J x 18 ET 65
11,0J x 18 ET 52
11,0J x 18 ET 40
11,0J x 18 ET 28
11,5J x 18 ET 33
12,0J x 18 ET 28
I would go for BBS RS GT wheels as suggested by Flying Finn and RS Man
Regarding the offset... the RS has many suspension adjustments. If it was me... I would stick with the factory size and offsets i.e ET 52 front and ET 65 rears. IMO of course
Definately the first one. You can squeeze in an 11 inch wheel on a NB if you have the rights offset, although I would not recommend it. I think David in LA is running 11x18" Gemballas in the rear with ET52 and rolled fenders.. I would personally go for the 10x18 ET 52 if you must choose between the two. Out of the two pics you first posted, I would go for #2! Good luck.
I think Flying Finn's picture is not RS-GT wheels but BBS Racing wheels.
I have a very good deal on the Gemballa wheels, that's why I would like to choose between those 2.
Finding the correct sizes is apparently not an easy task! :-)
Are you set on using those tire sizes? You could be more aggressive and go wider if you wanted to. But if you are going to run 265 rear tires then you should not be using 11" rims...10" is already stretching it. And for 225 fronts you should not use a rim wider than 8.5". From the list you posted above, I would go with 8.5" ET46 and 10" ET52.
