993 Forum 1995-1998
Jack Stand Recommendation
Old 05-09-2007 | 10:00 PM
GD993C4's Avatar
GD993C4
Default Jack Stand Recommendation
Can anyone recommend a good jack stand that is more secure than the typical "U" top jack stands available at Sear, Pep Boys, Auto Barn etc.?
Old 05-09-2007 | 10:39 PM
Tom W's Avatar
Tom W
The flat-topped stands from AC ( http://www.alltiresupply.com/p-3000NFP.html )
I switched to these and an Ac jack after my car slipped off my Sears jack and crunched a corner panel. It's cheaper to buy a good jack and stands than repair the car.
Old 05-09-2007 | 10:51 PM
jford's Avatar
jford
AC Jack Stand...as a lister said some time back "your safety demands it". They are not cheap but they are well worth the money. AC Jack is exceptional as well, I even lug mine to the track.
Once had over 100 (jackstands) of them in possesion......
Jamie
Old 05-09-2007 | 10:52 PM
mooty's Avatar
mooty
GT3 player par excellence
i 3rd the AC jack stands, i got two sets. well worth the money.
Old 05-09-2007 | 11:00 PM
AOW162435's Avatar
AOW162435
Seared
Gary,
Another enthusiastic vote for the AC stands. I have used these countless times already and would have no problem sleeping under my heavy 993 for a night - they are genuinly stout. I purchased four stands with the flat rubber tops, and two separate cradle-shaped inserts so that I can securely support my truck by its rear axle housing. I purchased mine from The Ultimate Garage and picked the stands up from the company's East Coast warehouse.
Some pics:
Andreas
Old 05-09-2007 | 11:11 PM
dwe8922's Avatar
dwe8922
I too have the AC stands and they are the best I've seen. You'll feel much better under the car, knowing you have the wide pad supporting the car instead of the two tips of a Y shaped prong that's meant to cradle an axle. The also have wide round pads on the feet, which are great for supporting the car on grassy ground at the track, and not sinking in it. Well worth the money.
Old 05-09-2007 | 11:38 PM
gr8nine93's Avatar
gr8nine93
Question. If one buys four, which only seems right considering their construction why would you not just go ahead and buy a hydraulic sissors hoist for a few more bucks----assuming of course that portability is not an issue?
Old 05-10-2007 | 12:09 AM
GD993C4's Avatar
GD993C4
Thanks for the advise. I will order them on Thursday. This forum is great!
Old 05-10-2007 | 03:33 AM
David in LA's Avatar
David in LA
AC jackstands from the group buy a few years ago
Quick Reply: Jack Stand Recommendation
