Transaxle bearings gone
While putting a clutch and LWF in my 993 my mechanic discovered that oil is leaking out around the rear axles. There is a lot of play and he thinks the bearings are shot. I am getting some humming noise from the rear under deceleration so I assume it is from the bearings.
Now for the questions:
Where in the Santa Rosa, San Rafael area can I get my transaxle worked on?
What else should I be doing while I am in there?
Interesting, I have a similar sound, but I thought it had to do w/ my B&B exhaust. What type of humming sound? I hear a humming/whurring when I let off around 5500-4200 RPM in 4th, 5th, and 6th gear.
Shawn, DeJung Motorsports in Cotati is a good solid shop. For top dollar you can go to S-Car-Go in San Rafael.
With the engine out of the car, depending upon mileage, consider replacing the SAI Check Valve, plugs, power steering belt, maybe plug wires, CV Boots/repack.
How's your first gear synchro? Is that easy to replace when he does the bearings, assuming it's bad?
My engine sound insulation pad is hanging a bit - you could do that too.
I just got back from the mechanic, the differential bearings are gone, you can move the axles up and down. What I really need is a place I can send the transmission so I can get the differential looked at and rebuild. I am looking for a shop with lots of experience rebuilding rear differentials.
Any suggestions from someone who has had this done?
