Fire extinguisher mount question
#46
I have the BK mount (that I got from Stable Energies) for my Recaro Pole Positions where the mount is secured between the side mounts and the sliders. It is tucked away quite nicely right up next to the seat (doesnt rub the passengers legs) and moves fore and aft with the passenger seat.
#47
Rennline mount on sale for July for $105
In June I asked Tim at Rennline if he could put their mount on sale for me at $105 again (I'm shameless). He said he was going to do just that in July. It's July, so I just bought one. Safety first!
http://www.rennline.com/Fire-Extingu.../products/766/
#48
Does anyone know what size and type the original 996 GT3 extinguishers are ?
Edit : Here it is : http://www.carnewal-europe.com/cpx_p96113.htm
About 8 lbs
About 8 lbs
#49
Noodle Jr.
#50
About 8 lbs
About 8 lbs
I also have it mounted on the drivers side instead of in front of the passenger seat as it's actually easier for me to reach below and get the extinguisher then it is to lean across to the passenger side...esp if a passengers leg is in the way. I'd like to to switch to the BK one-hand quick release mount but $250 is a bit much for a mount even though it looks slick
#52
Noodle Jr.
Hmm...I'm not looking forward to my new Rennline so much at this point. Maybe it can go on the driver side? At 6'3" it's already a PITA for me to get in, so how much worse can a fire extinguisher make it? BTW- I'm pretty comfy once I'm in, though.
#54
OK so I bit the bullet and bot the BK quick release mount....it's very well made and pretty slick but it better be for the price It is very easy and quick to remove and there are no straps that get in the way. A small benefit is that b/c of the way it attaches I actually got a little bit more room up front...but it doesn't really matter since no one drives this car except me so no real need to adjust the seats.
...I also have it mounted on the drivers side instead of in front of the passenger seat as it's actually easier for me to reach below and get the extinguisher then it is to lean across to the passenger side...esp if a passengers leg is in the way. I'd like to to switch to the BK one-hand quick release mount but $250 is a bit much for a mount even though it looks slick
#55
this works for me.
Cost me ~ $6 and an hour of labor cutting / sanding / drilling the 1/8" Al plate.
I sandwich the plate between the seat and the floor rails.
It's 2 piece so i can remove the extension part without fiddling with the seat if i want to.
easy - peasy.
Craig
easy - peasy.
Craig
#56
Since we are talking about fire supression, what do you guys think about this?
http://www.litegrip.com/firegrip.php
You could mount a couple on a harness bar or wherever you wanted.
#57
I have had a number of fire extinguishers/mounts and have found the best to be by Safecraft http://www.safecraft.com/. Search for pictures.
#58
Forgot to mention why I like it best. First, all billet aluminum. Two aluminum (heavy duty) straps around the bottle. Held to mount by bracket/heavy duty pin. Will not come loose in accident, but pull pin for quick release. Looks very snazzy as well (especially in the crinkle black).
No affiliation, just a happy customer.
SF
SF
#59
Sorry for the noob questions....
So do these cars catch on fire a lot?
Do I need to install a fire bottle?
Is this a track requirement?
Man.......will it ($$$$$) ever end?
TYIA
Bob-
TYIA
Bob-
#60
for what it is worth, I did the Stable Energies mount. I like the fact that it moves with the seat, however, it bounces up and down constantly. Pretty annoying.
So, I will either make my own or modify this one. When I get around to solving it I will post something
