Aftermarket HIDs
#181
Your ballast has a hot and a ground that connect to the yellow(hot) and brown(ground). Look at the pics on page 4. I used a tap in (aka suitcase) connector becuase I wasn't smart enough to pull off the bullet connector (on the brown wire). Over the years I've learned that I can apply enough force or torque to make anything come apart or move. I've also learned how to fix things that weren't supposed to come apart or move. Presently my 2 main tools for fixing my car are pen and checkbook.
#183
Wow nobody will say, wonder why....Oh well looks like I'll go with the 55 watt version. These guys lifetime guarantee their stuff (even the bulbs) & they have the digital slim ballasts.
NO affiliation whatsoever: http://www.retro-solutions.com/
#184
I don't know if HIDs work the same way, as once the xenon gas is ignited, and lit, I don't think it gets any brighter with more current.
I guess I don't really have an answer for you becuase I don't know the details of xenon lamps and how they work, but I can say, the 35W version that I have, is very bright. I have the 4300K temp.
#185
Sorry guys just one more follow up to this extremely long thread. First, I’m not sure why all the discussion on the installation of these kits. There are only two wires to deal with, Brown (OEM) negative to Black, and Red to (OEM) Yellow positive. SO simple, anyway, I’m very happy that I waited a year and half to perform this No-Brainer upgrade, back when this started there were only 35 watt kits available. I purchased the Digital brand HID 55 watt slim kit from http://www.retro-solutions.com/ as I said no affiliation. This kit required absolutely no modifications to the bulb mount, and everything fit easily into the headlight enclosure. I installed both sides in 20 minutes. I’m extremely happy with my kit and the limited lifetime warrantee on all the parts including bulbs. Now driving at night seems like day, truly unbelievable.
#186
HID's
...I'm not sure why all the discussion...Surfer2001
And we like to really savour these little upgrades.
And like richardew, my favourite tools are pen and check book, so my tech's installing my new kit, in a couple of months. In the meantime, the kit's at home, where I can admire it.
#187
Or are you using the 55w in the high beam?
#188
Surfer2001,
Which model did you buy. I see several different models on the retro-solutions web site. I see it took only 20 minutes per side. Was this truly plug and play or did you have to cut/splice wires.
Thanks for your help!
#189
It truly is a 20 minute job. 30 minutes if you triple-check every step. In this thread, there are posts referencing a barrel connector. If you can put a bullet connector on your new HIDs to connect to the barrel you pull out of the OEM light, it is plug and play.
I was very nervous, bought the connectors and printed out & highlighted multiple pages of this thread, but once I got the headlight buckets out on the kitchen table, it was really a cinch.
#190
Will,
thnks for the feedback! which kit did you order? Are the numbers related to the bulb size? Just being lazy I suppose....
I'm looking at over 12" of snow in my yard now so i may not tackle this project until the thaw!
#191
Almost full plug & play, I plugged the hot lead from the kit (RED) into the factory connector that plugs directly to the H1 blub. I did not use the bullet connector that some others used. For the ground I used one of those blue connectors in the picture see page 1 post # 6 of this thread. If you are looking for a part number from the vendor its: SKU: SLIM-55W-H1
HERE is the exact link: http://www.retrosolutionsllc.com/ser...D-XENON/Detail
By the way if you are in snow, that’s no excuse just pull the headlight enclosures out, and the do the job on your dinner table !!! LOL
Oh yea as for the police, no problem for me as most of my fam are in law enforcement. However, I certainly won't feel good if people are getting blinded. So far oncoming traffic has not been flashing their brights at me. I’m assuming that because my car is lowered with PSS9’s its not too bothersome.
ALSO I went with the 10000K color, the blue tint, looks very cool. if you are directly in front of the car, the blue is not that noticeable.
#192
Yes, need to specify "H1" as it is the size of the low-beem bulb.
You can do it...seriously. If I can, anyone can.
If you were in ATL and had a 6-pack of beer to share, I'd do it for ya.
#193
How about the car in front? When you're blinding it in both side mirrors and rear view mirror?
#195
UPDATE, it’s been just over one year and the passenger side is not lighting up. I followed the OEM warrantee instructions and swapped the ballast from side to side, they both worked for a few days then, again passenger side no workee.
I called retro-solutions and their sending a new set of bulbs, yes TWO new bulbs. They required $60.00 to send out the new bulbs, to be refunded when they receive my faulty ones. I’m a little disappointed they need 60 bucks, but that said it’s understandable.
