LPMM, UNHOLY SH!T!!!
#31
My sound clips should be running, search through on my putfile site. Let me know if any need refreshing as they can time out over the months.
Cheers,
David
Cheers,
David
#33
Originally Posted by Svaha
Caveman, which of your putfile clips corresponds to LPMM's?
#34
Originally Posted by TRINITONY
Tks..clamps are already off..the muffler is just hanging on the hook I guess...was to late to fuss with it. After unhooking everything I was wondering why the unk it wouldn't fall..of course after a lil research here I found out there's a hook..
Just got done taking the mufflers off. Theyr're some big cans..damm.
Anyways, can I or should I do the LPMM and allow for the heat shield or do away with the shields?
#37
#38
I did a few things:
1 - I replaced the bolts and lock nuts that hold the head sheilds with stainless steel ones.
2 - I used a zip blade (a very thin grinding blade that can we used on a hand held grinder) to do the rough cutting and then a air die grinder to get the curves in.
3 - I painted the shields with aluminum high temp header paint to freshen the look and protect the new exposed metal
4 - Now you can mount your nice and shiny heat shields on the mufflers again and go from there. They mufflers generate a lot of heat so you want the shields.
Cheers,
Mike
Cheers,
Mike
#40
Mark,
Apologies, I thought there were more LPMM clips. The only one is the one that Viggo referred to. Check out the older white 911 pulling away at Brands!
Cheers,
David
Cheers,
David
#41
Originally Posted by Mike J
I did a few things:
Cheers,
Mike
Cheers,
Mike
a) used the zip wheel and die grinder to 'saddle notch' the bypass pipe first.
b) when this pipe was a tight fit to the muffler pipes, it was traced with a Felt Tip pen.
c) used a hole saw to punch through and the die grinder to remove the rest prior to welding .... can't have any restriction
Think I'll redo the heat shields your way!
#43
Originally Posted by FisterD
Definately notch-out the heat shield to fit the new bypass pipe.
#44
It was 94 here today! It's hard to imagine it snowing anywhere. You've got to get that bad boy out, warmed up, and smack the tach a few times. That's when the beast is roused.
#45
next week
