993 Forum 1995-1998
kinematic toe in sf bay area
Old 03-01-2007, 06:54 PM
allill
allill's Avatar
Default kinematic toe in sf bay area
can anyone recomend a shop that does kinematic toe in sf or the peninsula?
Old 03-01-2007, 07:14 PM
Jim Morton
Jim Morton's Avatar
Roger Kraus Racing, Castro Valley, 510-582-5031
Brandon has use of my Autometrics Kinematic Toe tool, as well as he knows how to properly align a 993 !!!
Old 03-01-2007, 07:26 PM
cowtown
cowtown's Avatar
I've used Roger Kraus for my old '88 (no kinematic toe) and agree he's good.
Another option is Devek - they did a good job aligning and CBing my 993 and do have the kinematic toe tool.
Old 03-01-2007, 07:40 PM
Jim Morton
Jim Morton's Avatar
FWIW, I would be VERY interested in knowing if their Kinematic Toe tool is blue in color...
Old 03-01-2007, 07:53 PM
allill
allill's Avatar
any idea what each roughly charges?
Old 03-01-2007, 08:25 PM
Spuds993
Spuds993's Avatar
I had Brandon Kraus setup my 993 for the track (CB and align) and he charged me about $350 I believe. He used to setup my early 911 as well, always been happy with his work.
Funny thing, I mentioned to him that his name was being dropped in a positive way on this board (and Pelican), and he'd never heard of Rennlist
Maybe that's changed in the last year?
Old 03-01-2007, 08:51 PM
MarkD
MarkD's Avatar
another vote for Kraus. Brandon knows what he is doing and has the tool... thanks to Mr. Morton
Old 03-01-2007, 09:02 PM
FisterD
FisterD's Avatar
Brandon did mine as well.
Old 03-01-2007, 09:10 PM
ChrisA
ChrisA's Avatar
Another choice, Custom Alignment in Mountain View. Recently had a full alignment, yes with Kinematic. If I remember the alignment was $260.00 and forget what the CB was. No complaints the car feels great.
Old 03-01-2007, 09:21 PM
Tom W
Tom W's Avatar
Roger Kraus and Custom Alignment both do a good job (I've used both). I liked dealing with Brandon and the folk at Kraus a lot more and think they pay more attention to the details (especially when it comes to tires). I go all the way to Kraus and I live in HMB - I think it's worth the time/trip.
Old 03-01-2007, 10:05 PM
allill
allill's Avatar
Thanks for the responses.
Since I won't be tracking my car anytime soon, I don't need to get a corner balance, right?
Old 03-02-2007, 12:04 AM
RunRun
4th Gear
RunRun's Avatar
I vote for Roger Kraus also. Brandon set up my 993NA when I put in thr H&R coilovers with RS Sways. He spent at least 3 hours making sure everything is perfect (CB/alignment with Kin. toe/ride height). He also fixed the RS drop links that was separated due to my installation error. Throughly explained all my questions. Truly professional and nice guy.
Old 03-02-2007, 01:16 AM
Jim Morton
Jim Morton's Avatar
Not knowing what shock / spring setup you have, I would still recommend a corner balance if you have threaded collar spring perches on your shock assy's.
You might not need as much exactness on getting the corner balance zero'd such as with you in the car, but you should at least know your installed spring heights are close to being in range for each corner's weight load.
FWIW, I have seen several cars with shock setups installed by notable shops/wrenches where the corner weight has been off by a sizable amount due to misued or misunderstood ride height measurement points...
$0.02
Martin S.
Martin S.'s Avatar
Cool
If you have stock suspension...there ain't much to corner balance, considering that the rear ride hight can only be adjusted by shims, 3mm, 5.5mm and 8.0mm. That is not a lot.
Also, the front struts have minimal threading to permit a corner balance....as we have come to know them. With stock suspension, the factory set these cars up pretty well as I understand it...you don't need a corner balance. It's a Porsche car...they handle out of the box!
Old 03-02-2007, 01:21 AM
brucec59
brucec59's Avatar
One more vote for Roger Kraus Racing. They installed my M030 suspension and HDs. Alignment was $220. I didn't do corner balance.
Quick Reply: kinematic toe in sf bay area
